Offline ianlh
#1 Posted : 03 July 2020 15:57:17(UTC)
ianlh
I am a bit stumped with a what is probably a simple problem. I have a root solve in Mathcad that I just cant get to work in Smath, I have tried what I think is correct ways, but still not working, see below for example:
I have also tried stripping out the units, but still no luck
Hoping someone has the simple solution.
Ian
#2 Posted : 03 July 2020 19:05:46(UTC)
Always plot before solving !
Solve UNK.sm (213kb) downloaded 24 time(s).
Online overlord
#3 Posted : 04 July 2020 01:03:05(UTC)
Turkey
Ian
I have tried on Mathcad and it didn't work either.
Obviously there is a mistake with the formula.
You can't add kg*N/s^2 with kg/s^2. Units mismatch.
But if you divide the givens you can get the correct answer.
If this approach is true of course since we don't have more information.
Regards.
Online overlord
#4 Posted : 04 July 2020 03:37:54(UTC)
Turkey
Jean, direct question;
Are you being sarcastic about my comment?
#5 Posted : 04 July 2020 15:14:08(UTC)
I have removed my comment.
In my times, maths were unitless working well.
Now, put units in maths ... red results.
Offline Razonar
#6 Posted : 04 July 2020 21:00:31(UTC)
Razonar
Uruguay
Ian
Hi. Your setup is correct for Mathcad, but unfortunately SMath's solvers do not works like in Mathcad, and needs some help for use units.
SolveWithUnits.sm (17kb) downloaded 16 time(s).
Edited by user 04 July 2020 21:02:30(UTC)  | Reason: Not specified
thanks 3 users thanked Razonar for this useful post.
on 04/07/2020(UTC),  on 05/07/2020(UTC),  on 05/07/2020(UTC)
Online overlord
#7 Posted : 04 July 2020 22:16:18(UTC)
Turkey
I have checked with changing all inputs;
somehow the two formula give same calculation every time.
Offline ianlh
#8 Posted : 05 July 2020 13:29:58(UTC)
ianlh
Hi All,
Thanks for the help with this, I like the solution by Alvaro, seems the most elegant.
#9 Posted : 05 July 2020 16:14:25(UTC)
Unless you don't agree with yourself, solving SQRT implies the two solutions.
Presumably delimiting the range of the solvable project.
Offline Razonar
#10 Posted : 05 July 2020 20:30:31(UTC)
Razonar
Uruguay
Hi Overlord. You found an amazing symbolic solution for the original problem. I can't explain why, but my guess is that f1, f2 and f3 must to be related with the directors cosines or something like that.
Maple shows that your solution and the symbolic solution are the same, but must to force some "not-always-true" reductions in maple, with the command "maple(simplify(expression,symbolic))"
SolveWithUnits overlord.sm (36kb) downloaded 11 time(s).
SolveWithUnits overlord.pdf (98kb) downloaded 17 time(s).
on 15/07/2020(UTC)
Offline mkraska
#11 Posted : 06 July 2020 10:43:09(UTC)
mkraska
Once Maxima and the Maxima plugin are installed, you have a symbolic solver without unit issues.
solve.sm (10kb) downloaded 15 time(s).
on 06/07/2020(UTC)
