Joined: 25/02/2011(UTC) Posts: 9 Was thanked: 8 time(s) in 4 post(s)
Hi, I have created a programme to display a fractal tree in a 2D plot. fractal tree.sm (8kb) downloaded 29 time(s). fractal tree.pdf (210kb) downloaded 38 time(s).I would be interested to find out if there is a way to animate the plot process so that the fractal tree is drawn element by element, as each point is calculated. Can anyone give me any pointers on how to do it? If that is not possible, how would the animation be done after all the plot points are calculated? Thank you Gerard Bush Edited by user 15 March 2020 23:16:12(UTC)
| Reason: Not specified
1 user thanked Gerard Bush for this useful post.
Originally Posted by: Gerard Bush I would be interested to find out if there is a way to animate the plot process so that the fractal tree is drawn element by element, as each point is calculated. Like this ... in ½ points. fractal tree.sm (12kb) downloaded 27 time(s).
Originally Posted by: Gerard Bush I would be interested to find out if there is a way to animate the plot process so that the fractal tree is drawn element by element, as each point is calculated. ... hard to size the animation plot canvas. Otherwise renders well ½ length ... greedy 1533 frames ! Search "Samples"... "Pattern" for lot more. If you can't find and want more: please ask for. Cheers ... Jean Pattern fractal tree.sm (18kb) downloaded 15 time(s).
2 users thanked Jean Giraud for this useful post.
on 16/03/2020(UTC), on 16/03/2020(UTC)
Thank you Jean, That is just what I was looking for. To reduce the number of points, and reduce the calculation time the minimum length can be increased. For example, change 'if lenght > 0.25' in the tree function to 'if length > 1.0'. I guess this could even be defined as a variable. Cheers, Gerard Pattern fractal tree.sm (19kb) downloaded 18 time(s).Edited by user 16 March 2020 14:22:12(UTC)
Joined: 15/07/2010(UTC) Posts: 437 Location: Beer-Sheva Was thanked: 520 time(s) in 288 post(s)
5 users thanked Ber7 for this useful post.
on 16/03/2020(UTC), on 16/03/2020(UTC), on 16/03/2020(UTC), on 16/03/2020(UTC), on 17/03/2020(UTC)
Thank you very much, Jean and Ber7 for your additions!
3 users thanked Ber7 for this useful post.
on 18/03/2020(UTC), on 18/03/2020(UTC), on 19/03/2020(UTC)
