2 Pages12>
Offline Ale16595
#1 Posted : 21 December 2019 13:50:00(UTC)
Ale16595
Hello everyone! I wanted to know if it is possible to solve differential equations with Smath Studio. in particular I would be interested in solving ordinary nonlinear second order differential equations.
Thanks in advance.
Offline mkraska
#2 Posted : 21 December 2019 14:47:59(UTC)
mkraska
Was thanked: 1126 time(s) in 723 post(s)
In the interactive handbook (see Tools> Plugins> Interactive books (switch to online gallery)) there is a section
Mathematics> Ordinary Differential Equations.
In the examples subsection you find a variety of non-linear ODEs with numerical and symbolic solutions (based on Maxima plugin).
Offline Ale16595
#3 Posted : 21 December 2019 15:11:51(UTC)
Ale16595
Thank you very much.
Cheers
#4 Posted : 21 December 2019 17:17:44(UTC)
Thanks in advance.
Please: attach DE.
#5 Posted : 21 December 2019 20:18:45(UTC)
... here is an example:
ODE Lorenz Attractor Publish.sm (16kb) downloaded 109 time(s).
Offline Ale16595
#6 Posted : 22 December 2019 15:21:49(UTC)
Ale16595
Hi, the differential equations that i should solve are like the ones in the picture:
here is also the .sm file… Documento2 DE.sm (22kb) downloaded 45 time(s).
#7 Posted : 22 December 2019 16:20:10(UTC)
φ''(t) ... is not defined
Documento2 DE.sm (26kb) downloaded 52 time(s).
Alvaro has done lot of work on that one, few days ago
it was about tangent, curvature ... As it look: same system.
#8 Posted : 22 December 2019 16:37:33(UTC)
... revisit your original document 11 days ago.
revisit Alvaro reply.
curvatura (1 doctored).sm (54kb) downloaded 56 time(s).
Offline Ale16595
#9 Posted : 22 December 2019 20:03:53(UTC)
Ale16595
Yes, the problem is the same as a few days ago. This time, however, I had to modify it slightly and I must be able to derive the psi and phi functions using the differential equations in the figure.
#10 Posted : 22 December 2019 23:11:17(UTC)
... still undefined wrt φ'(t)
If you can help more: please re-post this document
so to avoid refactoring.
If you have the original work out and solution it
might help converting to Smath
Documento2 DE [explain more].sm (34kb) downloaded 46 time(s).
Offline Ale16595
#11 Posted : 23 December 2019 18:12:02(UTC)
Ale16595
Why should i define the phi function?
Should I get it by solving the differential equation, or am I wrong?
#12 Posted : 23 December 2019 20:46:23(UTC)
You are right, after the numerical ODE solver you will have
the manipulate the solution depending upon sin/cos
The 2nd term is not a simple coefficient. That induces FinDiff.
So, you have nothing from source ? Pure invention top/bottom.
Documento2 DE [explain more].sm (67kb) downloaded 28 time(s).
#13 Posted : 24 December 2019 00:03:01(UTC)
... a short revisit.
ODE Compendium_1.sm (155kb) downloaded 55 time(s).
#14 Posted : 24 December 2019 05:01:55(UTC)
... that's as far as I can make this project respond.
Not enough insight to go further.
Page57 ODE.sm (13kb) downloaded 45 time(s).
#15 Posted : 24 December 2019 15:02:40(UTC)
... your original parameters send the DE solutions in the zillion domain.
Zillion domain is no maths, something does not cut the mustard in there.
Better sanity with other CAS ...
Documento2 DE [explain more].sm (46kb) downloaded 26 time(s).
Offline Ale16595
#16 Posted : 24 December 2019 19:12:05(UTC)
Ale16595
Hi, thanks for the help and patience.
This is a task I have been assigned and I am not following any source.
If it can be helpful to derive the function phi, I know that:
-for t=0, phi=0
-for t=6.187, phi=0.867 and phi'=0
#17 Posted : 25 December 2019 05:31:28(UTC)
-for t=0, phi=0
we have that from freaking p1 parameter
and obviously phi'=0
for t=0, phi=0 ...that can't be
whereas the system starts @ IC 0.005
1. Make sure the DE as proposed is OK
2. What software the presumed assignment is based on ?
... it could be wrong from the onset !!!
Documento2 DE [explain more].sm (49kb) downloaded 22 time(s).
Offline Ale16595
#18 Posted : 25 December 2019 13:19:07(UTC)
Ale16595
I modified some values ​​and a relationship because I noticed an error.
The differential equation, on the other hand, should be correct because it comes out of the physical problem it is trying to solve.
As for the assignment of values, I always get them from the physical system knowing more or less the trend of the phi function to be obtained.
If it can help the progress of this function it is the following:
-The phi function starts from 0.147 for t = 0, grows up to a maximum equal to 0.867 for t = 6.187 and finally decreases
-The function phi' instead starts from a value 0 for t = 0, in the interval between t = 0 and t = 6.187 reaches a maximum and then returns to 0 when t = 6.187
Then I would have a question, why does phi' appear in the differential equation and not phi?
#19 Posted : 25 December 2019 16:21:29(UTC)
Good question: you are the Man who proposed the DE phi'.
For your above attempted explanation, you are just presuming.
1. Setup the DE ... as per the assignment
2. Confirm the reference solver software the Originator is using.
Will be back while waiting.
The project is pure blue sky ... sending a fly to Cirus ?
#20 Posted : 26 December 2019 15:51:56(UTC)
Does the CannonBall project suggest something ?
Maths Cannonball.sm (30kb) downloaded 67 time(s).
Similar Topics
A Small Bug in Differential Equations Display (Bugs & Problems)
by PDG 16/06/2018 21:43:24(UTC)
2 Pages12>
