Hello everyone! I have difficulty plotting the function c which depends on the derivatives of two functions which in turn depend on the parameter t. Could anyone help me? This in the smath file.. curvatura.sm (12kb) downloaded 13 time(s).Thank you so much
Joined: 10/12/2009(UTC) Posts: 247 Location: Cali, Colombia Was thanked: 87 time(s) in 66 post(s)
Originally Posted by: Ale16595 Hello everyone! I have difficulty plotting the function c which depends on the derivatives of two functions which in turn depend on the parameter t... Maybe this is what you want... ... and the .sm file: curvatura1.sm (10kb) downloaded 18 time(s).
Originally Posted by: Ale16595 Could anyone help me ? To plot both systems ... Jean curvatura.sm (12kb) downloaded 33 time(s). Maths Tangent.sm (92kb) downloaded 33 time(s).
thank you very much for your help, I hope I have no more problems
Originally Posted by: Ale16595 thank you very much for your help, I hope I have no more problems You´re welcome. It's okay to ask, because you express the need to know. It is better to ask than keep silence
Thank you very much for the availability. But I need more help. How can I draw the tangent line to the equation in parametric form? this is the file … curvatura2.sm (13kb) downloaded 17 time(s).
Hi Ale. Here, some ways. curvatura3.sm (26kb) downloaded 17 time(s). curvatura4.sm (21kb) downloaded 23 time(s).Best regards. Alvaro
Originally Posted by: Ale16595 Thank you very much for the availability. But I need more help. How can I draw the tangent line to the equation in parametric form? For the Tangent over C(t), it will follow the scalar rules of the document Tangent.sm posted before. The Tangent over the parabola is another business. Smath does not derive linterp(x) as it is NOT a function only an interpolation. This project and lot more are rescued via Infinitesimal Analysis [dates back before CAS]. For that particular typical user point of tangency, OK. You may want to experiment more . Don't mind to see noisy curvature [disabled in collapsed]. Chers ... Jean. curvatura2 Copy.sm (31kb) downloaded 15 time(s).
Thanks for the answers. But if I wanted to find the tangent to the curve when the parameter t changes, how should I do?
Originally Posted by: Ale16595 Thanks for the answers. But if I wanted to find the tangent to the curve when the parameter t changes, how should I do? Do you mean the envelope, all the tangents for the range en T? curvatura5 - envelope.sm (24kb) downloaded 23 time(s).Best regars. Alvaro. Edited by user 06 December 2019 20:52:48(UTC)
| Reason: Not specified
Originally Posted by: Razonar Hi Ale. Here, some ways. Thanks Alvaro ... superb/saved ... Jean
Your project has been refactored strictly on discrete. OK, you have functions but life is from collected data. Collected data are always noisy from the quantization, a small amount of Gaussian Ksmooth is often sufficient. Ksmooth being applied before cinterp As exemplified, cinterp is the best interpolator for a clean curvature plot from infinitesimal maths. I don't understand what your were attempting c(t) last module. Please, don't hesitate for more. Cheers ... Jean Maths Tangent Data Set Copy.sm (37kb) downloaded 19 time(s).
Originally Posted by: Jean Giraud Your project has been refactored strictly on discrete. O .... more maths are coming: cumulative integration, arc length derivative you already have it from last attachment.
Thank you very much for the help, I appreciate it very much. I hope to be able to continue alone. kind regards
Originally Posted by: Ale16595 Thank you very much for the help, I appreciate it very much. I hope to be able to continue alone. kind regards Your project now all done, based on discrete collected data, collected data that you will have to smooth [not offered]. Smoothing is a large Engineering tool box ! I hope to be able to continue alone.Let's see the continued adventure. Cheers ... Jean Maths Tangent Data Set.sm (61kb) downloaded 24 time(s).
