Good day. How to find a formula to determine automatically? Also how do you replace values and combine all formulas into one automatically?
Originally Posted by: Вуаутвук How to find a formula to determine automatically? You mean: solve for λ
2 users thanked Jean Giraud for this useful post.
on 14/11/2019(UTC), on 15/11/2019(UTC)
4 users thanked Razonar for this useful post.
on 14/11/2019(UTC), on 14/11/2019(UTC), on 14/11/2019(UTC), on 15/11/2019(UTC)
Originally Posted by: Razonar Hi. Try this too. Needs a " Nightly builds": . I meant. Is it possible to automatically convert a formula to find a value from it? Type as in the example in the picture isol2.sm (34kb) downloaded 35 time(s).Best regards. Alvaro. Edited by user 14 November 2019 17:33:46(UTC)
| Reason: Not specified
Hi Вуаутвук. Do you have the " Nightly builds"? (Download it at the link). I use a very recent new behavior, not pressent in the stable beta versions). Best regards. Alvaro.
I have the latest version. Best regards. Alvaro.
Originally Posted by: Вуаутвук I have the latest version.
Ok. Do you evaluate symbolically d? Best regards. Alvaro. Edited by user 14 November 2019 19:03:52(UTC)
Originally Posted by: Razonar Originally Posted by: Вуаутвук I have the latest version.
I want to convert the formula from P = to formula D =. In symbolic form.
I'm understood, thank you.
... complete/publish
Originally Posted by: Jean Giraud I didn't quite understand what it was, but thank you.
Originally Posted by: Вуаутвук I didn't quite understand what it was, but thank you. Read like this: 1. 'f' is an expression, i.e: a formula 2. it depends upon 10 parameters from blue sky 3. you wanted its result be 'P' call it "unk" [unknown] 4. if you can measure then assign 9 parameters, there is one left not measured then "unk' 5. you said you wanted to solve for 'd', given all 9 other parameters and the result "unk" solving for 'd' is the maple implicit solve block maple(solve(unk-f,d)) ... evaluate symbolic. 6. symbolic expresses 'd' wrt all 9 given parameters and the demanded "unk" implicit unk-f means unk-f=0
Originally Posted by: Jean Giraud Originally Posted by: Вуаутвук
I can not do it
Originally Posted by: Вуаутвук I can not do it Please: attach the Smath document. Once patients are doctored => recycled !
003.sm (51kb) downloaded 9 time(s).
... suite Here is doctored in pink [2 regions]. Your original SS 7251 opened/doctored in my SS 6179 returned SS 6179. If you don't see the graph, please let me know. In that case, I will make a snippet. 003.sm (69kb) downloaded 11 time(s).
Hi Вуаутвук. Some notes: - Use units. For instance, alpha=45 isn't usual, but alpha=45*deg is. - R.max^3-R.min^3 is more usual than R.min^3-R.max^3. - You can't solve P with the same equation from "f". - Empirical coeffs usually carry some units. I don't know very well the process that you're describing, but guess that this is a good aprox to the correct solution. 003.sm (50kb) downloaded 12 time(s).Best regards. Alvaro.
