SMath Studio Forum
Questions
I would like to plot this function
I have attached a Reflection.sm (51kb) downloaded 14 time(s). .sm file containing a computation I would very much like to plot. The geometry is shown in the picture below. Can someone help ? Thanks, Reflection.sm (51kb) downloaded 14 time(s).
Oh ! ... your proposal is not much productive, is it ? The picture is strictly discontinuous. Reflection.sm (55kb) downloaded 6 time(s).
I don't think L is discontinuous for ddegrees in the range 0 to 60. What am I missing here ? L(ddegrees) should vary smoothly from L(0) to L(60) Edited by user 14 October 2019 00:37:29(UTC)
| Reason: Not specified
Originally Posted by: mangurian What am I missing here ? You are missing to plot the literal demo diagram, here is as per your inputs [a,b,s,t]. More is missing from incomplete project description. Reflection [abst].sm (63kb) downloaded 8 time(s).
Originally Posted by: Jean Giraud You are missing to plot the literal demo diagram, here is as per your inputs [a,b,s,t]. More is missing from incomplete project description. Refreshed from your literal inputs. You may have to revisit your College Physics book. Cheers ... Don't hesitate. Reflection [abst].sm (129kb) downloaded 10 time(s).
Joined: 23/03/2016(UTC) Posts: 277 Was thanked: 91 time(s) in 57 post(s)
Originally Posted by: mangurian I don't think L is discontinuous for ddegrees in the range 0 to 60.
L(ddegrees) should vary smoothly from L(0) to L(60) Yes the length L is continuous with respect to ddegrees. I think Jean misunderstands the question. See attached. (A little sloppy but it works) Edit: Updated graph to add labels Edit2: Had an error in definition of L. Fixed. Reflection_alyles.sm (178kb) downloaded 8 time(s).Edited by user 14 October 2019 18:04:54(UTC)
Originally Posted by: alyles I think Jean misunderstands the question. Quite right: misunderstood the travelling distance vs °incidence. Thanks, interesting project. We need more real projects. Reflection [abst, alyles].sm (187kb) downloaded 6 time(s).
... You can have it to a good degree of accuracy as a continuous function, though a bit strange. Reflection [abst, alyles].sm (253kb) downloaded 5 time(s).
Originally Posted by: Jean Giraud ... You can have it to a good degree of accuracy as a continuous function, though a bit strange.
FYI Jean you're using one of my earlier files where I had a copy paste error in the derivation of L(d), the second root term should only have s*tan(d*pi/180). You can get rid of the "c-" |
Originally Posted by: alyles FYI Jean you're using one of my earlier files where I had a copy paste error in the derivation of L(d), the second root term should only have s*tan(d*pi/180). You can get rid of the "c-" Thanks ... updated. The model fit is brute force, limited. From my 100's models, not one immediate. If interested: let me know, not sure if possible. Reflection [abst, alyles].sm (210kb) downloaded 4 time(s).
I understand the idea to tabulate as demanded, in fact useless as you have the continuous function. Purely Edu. LinfitCheby added. No problem to export as a function. Thanks alyles for completing the project. Reflection [abst, alyles].sm (233kb) downloaded 11 time(s).
SMath Studio Forum
Questions
