Offline Xiu12
#1 Posted : 20 September 2019 21:34:48(UTC)
Xiu12
I'm trying to write a function that I can use to calculate the surface area. The function is to be based on data from a matrix with n elements
I ran out of ideas. I guess the problem is in a loop.
I attach a file and an image.
I will be grateful for your help.
Integral.sm (8kb) downloaded 10 time(s).
Offline alyles
#2 Posted : 20 September 2019 23:22:30(UTC)
alyles
You can define piecewise function this way. Haven't figured out integration yet. Built in int() function doesn't seem to work.
Piecewise Function.sm (7kb) downloaded 15 time(s).
#3 Posted : 21 September 2019 01:56:29(UTC)
That was lavishly exemplified few hours ago.
Your drawing needs some project intention about,
i.e: what is what for what.
#4 Posted : 21 September 2019 02:15:38(UTC)
Latest version is all white. Could discover the blank regions,
framed the regions, added background.
#5 Posted : 21 September 2019 02:37:44(UTC)
Offline uni
#6 Posted : 21 September 2019 02:46:37(UTC)
uni
You can try something like this
Russia ☭ forever
Viacheslav N. Mezentsev
#7 Posted : 21 September 2019 05:29:09(UTC)
Annotate the drawing [what is what in there], and what wort what.
MatrixUnknown.sm (10kb) downloaded 12 time(s).
Offline Xiu12
#8 Posted : 21 September 2019 10:37:10(UTC)
Xiu12
Thank you guys for your answers,
I will try to explain what I need.
Depending on the soil layers, I have a graph similar to the picture. At a later stage, I want to divide this chart into equal pieces (for example 0.25 m or 0.5m) to obtain "soil springs".
To simplify the example, I assumed that the elements of the K matrix are constant.
Edited by user 21 September 2019 10:39:52(UTC)  | Reason: Not specified
Offline mkraska
#9 Posted : 21 September 2019 11:47:47(UTC)
mkraska
uint.sm (10kb) downloaded 17 time(s).
on 21/09/2019(UTC),  on 21/09/2019(UTC)
#10 Posted : 21 September 2019 17:23:03(UTC)
OK ... from there, apply your skill to produce the Cartesian graph
of the piecewise soil. No problem to integrate.
Integration of discontinuous functions is deceiving.
Two models attached. The Romberg-Simpson is more accurate.
Example 2, the integration is known by inspection.
Isn't deceiving Simpson is not so good !
Integrate Discontinuous_2.sm (132kb) downloaded 10 time(s).
#11 Posted : 21 September 2019 20:12:23(UTC)
Total integration is often what the project needs.
Most Engineering projects require the evolution of the integration,
i.e: the cumulative integration.
The attached takes Martin data set, convex Hermite
that you can fillet [sub:=,] and populate at will [mesh 't'].
The latest step is the FD integration [Finite Differences].
The graph shows the evolution of the integration.
The end point of the cumulative = total integration
from any other best/applicable numerical integrator.
Except for trivial cases no numerical integration is exact.
FD integration is always very accurate [kind of yardstick].
Hermite polyline is very similar to CAD systems.
Please, come back on that "Soil project".
Integrate Discontinuous_3 [HermiteSpline, FD].sm (50kb) downloaded 6 time(s).
#12 Posted : 21 September 2019 20:16:46(UTC)
True Viacheslav: ODE integrator(s) are very excellent.
Thanks for your input.
#13 Posted : 21 September 2019 23:18:55(UTC)
... some didactic added.
OBSERVE: before the CAS numerical integration,
integration was FD [Finite Differences].
Read: F.B. Hildebrand.
Integrate Discontinuous_3 [HermiteSpline, FD].sm (115kb) downloaded 12 time(s).
Offline Xiu12
#14 Posted : 22 September 2019 12:57:11(UTC)
Xiu12
Thank you very much,
(btw the "thank" button on this page does not work)
The idea of ​​using linterp is actually much better instead of a loop.
Below is the file with the result I needed.
Final springs.sm (21kb) downloaded 11 time(s).
Edited by user 22 September 2019 13:00:23(UTC)  | Reason: Not specified
#15 Posted : 22 September 2019 15:43:08(UTC)
The idea of using linterp is actually much better instead of a loop.
The "Tanks" button used to work years ago, not any more.
Good work ... two comments:
1. subscript is confusing with sub-sub index.
Very many projects are sub-sub indexed.
Reserve subscript as tutorial [exemplified].
2. variable name confusing with number is another killer.
you had 1:=max(X).
SS7030 was reputed good version, compatible SS 6179.
Final springs_1.sm (25kb) downloaded 14 time(s).
#16 Posted : 22 September 2019 19:56:55(UTC)
... for convenience and publishing:
you can sub-space [at will] your calculated segments.
From there, you may obtain the cumulative integration
from the FD as offered before.
Final springs_1.sm (43kb) downloaded 9 time(s).
#17 Posted : 22 September 2019 21:32:32(UTC)
... directly from the sampled data.
Subspace is a great utility.
Soil Simplifed from Sampled Data.sm (19kb) downloaded 21 time(s).
Guest (2)
