SMath Studio Forum
Questions
Roark Mathcad interactive Book
Joined: 10/11/2017(UTC) Posts: 15 Was thanked: 2 time(s) in 2 post(s)
Rank: Advanced Member Groups: Registered, Advanced Member Joined: 13/01/2012(UTC) Posts: 2,648 Location: Italy Was thanked: 1329 time(s) in 875 post(s)
They are .mcd binary files, there's no way to open them because are encoded in a prorietary format. |
Ok,
Thank you a lot for the fast answer.
Originally Posted by: Raztua I was wondering if there is any way to open the "Roarkâs formulas for Stress and Strain" mathcad handbook? My answer is NO ... Smath is not a Mathcad clone. What I have from Mathcad 8 Pro up to Case 12.a All that stuff are only formulas, but not only formulas. Each example, thus each eventual application case are base on the solve bloc Given/Find [linear] Smath does have such coded solver. Very many Mathcad Given/Find have been solved in Smath via its own solver. Best example is Frobenius, Quaternion ... I see no problem making an Smath Roark, quite a project. It should be no problem adapting the units ISO [metric]. Put the stuff up to Case 5a in Smath document, attach in this Forum for eventual collaboration. Cheers ... Jean
Originally Posted by: Jean Giraud Smath does have such coded solver. Smath does not have ...
Originally Posted by: Raztua As was wondering if their is any way to open the "Roarkâs formulas for Stress and Strain" mathcad handbook? It is possible, but you need to convert all mcd files to xmcd format. You can do it manually using Mathcad 11. After that you can try open xmcd files in SMath Studio. |
Originally Posted by: uni It is possible, but you need to convert all mcd files to xmcd format. You can do it manually using Mathcad 11. After that you can try open xmcd files in SMath Studio. That stuff is Mathsoft from Mathsoft, i.e: from Mathcad. The collab has that stuff, just to be converted Given/Find. Smath is not going to convert Given/Find. That bloc is Mathsoft property. I'm saying that because you are suggesting Smath will run.
Dear all, I took some time rewriting the roark for Smath, It is not finished yet, and I am still working on it on my spare time, as it improve both my understanding of smath, and structural calculation. Many calculations can be done in other way, and if pple find a faster, or more interesting way to solve some equation/problems, i would be really interested, and integrate it. roark v0.1.7z (1,561kb) downloaded 48 time(s).One last question: My aim is to make an handbook, how can i perform this? Thankyou, Regards, Pierre
Hello Pierre, Simply attach your *.sm document to read at opening. Thanks, Jean.
Hello I think the interactive book query can help you Best Regards Carlos
Joined: 15/04/2012(UTC) Posts: 1,987 Was thanked: 1124 time(s) in 721 post(s)
Originally Posted by: Raztua Dear all, I took some time rewriting the roark for Smath, It is not finished yet, and I am still working on it on my spare time, as it improve both my understanding of smath, and structural calculation. Many calculations can be done in other way, and if pple find a faster, or more interesting way to solve some equation/problems, i would be really interested, and integrate it. roark v0.1.7z (1,561kb) downloaded 48 time(s).One last question: My aim is to make an handbook, how can i perform this? Thankyou, Regards, Pierre The links in your book don't work for me. It seems that batch production of links using the toolbox from the text region utilities plugin don't produce valid links any more. So you might have to edit the xml file as I had to when I started to create the interactive handbook. |
Hi, I am new Smath. I was trying to open Mathcad file (.xmcd). The page went blank. Would you help? Thank you.
SMath Studio Forum
Questions
