#1 Posted : 24 August 2019 15:12:06(UTC)
Hello Radovan and Grand Doctors,
Earlier you mentioned symbolic bug, this confirms your finding.
Maths Overflow [Max above limit].sm (20kb) downloaded 12 time(s).
Offline uni
#2 Posted : 24 August 2019 17:41:27(UTC)
uni
If you see long lines with numbers, this means that everything works correctly. That is how it should be. Here symbolic calculations use string coding to achieve arbitrary precision. In fact, everything is much more complicated there.
If you really want to know how the symbolic engine works, then you can look at this project: Tiny.Science.
If you wonder where large integers come from, you can research this project: SymbolicC++
Thus, errors when working at the boundaries of ranges are associated with the correct operation with long integers. This correct operation is not always reducible to the area of floating point numbers. Also, a symbolic description can be difficult to reproduce in an interface. Here you need to be very careful.
Russia ☭ forever
Viacheslav N. Mezentsev
#3 Posted : 24 August 2019 20:04:42(UTC)
Thanks Viacheslav for visiting.
For your delight, the attached has the above max and an apparently doctored
unfortunately the doctored is freaked lot worst than the red.
As it looks, the freaked are so from Maple .
Many of the Thiele continued fraction have been converted to J_Frac successfully.
Many more just can't because of the above max.
Same Thiele as proposed, Mathcad 11 spits out perfect.
Thiele_000 Transit_Convert Doctored_Freaked.sm (25kb) downloaded 11 time(s).
#4 Posted : 24 August 2019 22:10:32(UTC)
... the attached is not Thiele at all, simply a matrix data project.
Works fine SS 6179 ... red at Radovan and the originator [SS 7109].
Project does not generate "above max" SS 6179,
why does it SS 7109 ... Question for Doc Watson.
Project Fission.sm (188kb) downloaded 10 time(s).
