Hello Everyone,
First of all, congratulations for such an amazing program.
I would like to ask if there is a way to automate SMath through an external code. I would like to, from a C# .Net program: 1- Open a SMath sheet. 2- Change some input variables. 3- Calculate it. 4- Acquire back the value of some variables. 5- Possibly print the sheet to PDF.
Is there, at least, a way to control (i.e. do these things) the program programatically using the plugins? Because if this is possible, then one may create a listener plugin that would expose this functionality to other programs.
Thank you for the assistance.
My suggestion is to act like for the Run plugin: - Create your SMath worksheet with entry data from files, return data calculated by SS to files;
- Run the worksheet using command prompt (Process.Start in C#);
- In the external programs, create and read the input/output files;
Alternatively, you can deal with the xml code of the worksheet like done by ghMath plugin. |
Hi Davide,
Thank you so much for that. It was really what I was looking for!
- Rafael
