SMath Studio Forum
Questions
Numeric integration boundary assignation
Joined: 15/09/2012(UTC) Posts: 20 Location: Quebec Was thanked: 2 time(s) in 2 post(s)
Hello, I was writing an example and meet a possible issue. Look at the attached file, is it normal to not being able to assign directly t.1 and t.n to the integral interval? ISERROR QUESTION MARK.sm (15kb) downloaded 11 time(s).Thank you
attention: you used "t" both as a vector and as an integration variable sergio
1 user thanked PompelmoTell for this useful post.
Originally Posted by: Guy Payeur I was writing an example and meet a possible issue. Like this ... ISERROR QUESTION MARK.sm (17kb) downloaded 13 time(s).
Thank you Jean for your example of cumulative integration. That was my next step :-) Still, I found that the integration variable is not quite independent (local) to the integral function. Should it be the case? See the attached file. ISERROR QUESTION MARK_2.sm (17kb) downloaded 7 time(s).
Joined: 28/08/2014(UTC) Posts: 1,369 Was thanked: 829 time(s) in 525 post(s)
Originally Posted by: Guy Payeur Thank you Jean for your example of cumulative integration. That was my next step :-)
Hi. It isn't in other software, like maple. Usually it must to be an undefined name: Best regards Alvaro.
Originally Posted by: Guy Payeur Still, I found that the integration variable is not quite independent (local) to the integral function. Yes, like in Mathcad, in the wild domain of integration Doctored in red, attached ... Cheers ... Jean ISERROR QUESTION MARK_2.sm (19kb) downloaded 9 time(s).
Using wild value for x axis brought plots that look a lot better. Thank you Jean. I guess that integration range meant not to be mixed with the integration variable. That does not disturb the calculation, but was only a bit counter intuitive. Thanks for all (Jean, Alvaro and Sergio) ISERROR QUESTION MARK_3.sm (58kb) downloaded 8 time(s).
Originally Posted by: Guy Payeur I guess that integration range meant not to be mixed with the integration variable. That does not disturb the calculation, but was only a bit counter intuitive. Same in Mathcad/Mathsoft. Read more in the attached from Drummondville. Salut Voisin ! .. Jean Integrate Compendium_000 Indefinite.sm (11kb) downloaded 10 time(s).
Ok, so this worked because 'x' is the variable name for the vanishing iterator. Also worked because 'z' is a passing variable that will be iterated by 'x' in the plot. Would you explain why [-2..2] is 222 pixels? Should this be correlated to the window resolution? And not being a fixed value? Thank you
Originally Posted by: Guy Payeur Would you explain why [-2..2] is 222 pixels? Should this be correlated to the window resolution? And not being a fixed value? I copied the plot from another document, as it was then calipered. Smath native 2D plot are adjustable by pixel in both directions. Very nice to get pleasant looking side by side up/down plots. Mathcad used to be not by pixel, rater by ½ pica. Thus not fine trace and never none two of same size. The other gorgeous plots are OriginLab. Not a function plotter but plot XY data joined by spline(s) on pixels. When you Shift+@ you get the native Smath canvas 232 150 Windows screen resolution is 96 ppi [PixelPerInch]. Thus eye fatigue on long term use because the internal EyeFourierTransform must convert to the normal eye resolution "normalized" 1200 ppi. Read more about indefinite integral plots ... Jean Integrate Compendium_000 Indefinite.sm (20kb) downloaded 11 time(s).
Originally Posted by: Guy Payeur Would you explain why [-2..2] is 222 pixels? Should this be correlated to the window resolution? And not being a fixed value? Another interesting visit ... It would be on prescribed pixels if the cumulative would be discretized instead of scalar. In the attached the f(x) looks monster big to calculates, not so. f(x) is given in the Smath executable format. Integrate_00000 [ RECAST Scalar].sm (14kb) downloaded 7 time(s).
SMath Studio Forum
Questions
