Offline Britt1
#1 Posted : 09 April 2019 19:49:30(UTC)
Britt1
Is there a find and replace function for formulas? Example, you have a bunch of formulas that have a subscript of 11 in variables, and you want to change all of the 11's to 3's?
#2 Posted : 09 April 2019 21:20:26(UTC)
Yes.
In a single math region, you can use the F8 key an you'll be able to rename all local variables/functions at once.
Globally, you can do it with the Text Region Utilities plugin.
Edited by user 09 April 2019 21:36:57(UTC)  | Reason: Not specified
Offline Britt1
#3 Posted : 09 April 2019 21:27:40(UTC)
Britt1
In a text region, nothing happens if I push "F8". Also, I have the text region utilities plugin on SMath, but don't know how to access it in the sheets. Also, I was also asking how to do this in an actual formula, not a text region.
#4 Posted : 09 April 2019 21:34:12(UTC)
True, edited. Good
Go to "Insert" > "Text region utilities" > "Toolbox"
This will add a small region in the worksheet. Right clik on the region to access the "Search and replace" dialog. You might have to evaluate the worksheet to make it working properly.
Both F8 and the TRU dialog are able to do that, just play with the options (uncheck "Text regions", check meaningful math options).
Edited by user 09 April 2019 21:36:33(UTC)  | Reason: Not specified
Offline Britt1
#5 Posted : 09 April 2019 21:39:46(UTC)
Britt1
Do the above apply to version 0.99 (build: 7005)? our computer people have not updated to the current version.
Offline Britt1
#6 Posted : 09 April 2019 21:48:07(UTC)
Britt1
I don't see a "toolbox" under "text region utilities". Also, what do you mean by "evaluate the worksheet"?
#7 Posted : 09 April 2019 21:57:02(UTC)
It's the third item: "Insert a toolbox"
TRU
Perform a calculation of the whole worksheet.
You can do it by pressing F9 or with the menu option "Calculation" > "Recalculate page" or using the green "refresh arrows" in the toolbar.
#8 Posted : 09 April 2019 22:02:04(UTC)
subscript(s) as number is pest. In general, subscripts just confuse
unless they are for didactic demo. If you have literal subscript(s)
it might then be easier to change via text.
.... example mnemonic ...type 'J' thermocouple in the range up 356 °C
J_356(mV):=f(x,Cool
Offline Britt1
#9 Posted : 09 April 2019 22:09:46(UTC)
Britt1
TRU
In my pulldown, there is nothing below "text region", except for "region protection"
#10 Posted : 09 April 2019 22:25:57(UTC)
It's an old screenshot, unfortunately I'm from smartphone and I can't make an actual one.
However since a while items in insert menu are sorted by type (folders then simple items) and by name a to z, if you have it should be one of last folders
Offline Britt1
#11 Posted : 09 April 2019 22:29:58(UTC)
Britt1
"insert a toolbox" or toolbox, is not there, as far as I can see.
#12 Posted : 09 April 2019 22:50:46(UTC)
Then go to tools > plugins, and with the top right button set as "local storage" check if the plugin is in the list.
If it's there and disabled, you can enable it again.
If is missing, change the top button to "online gallery" and you can install it from the list.
Offline Britt1
#13 Posted : 09 April 2019 22:58:38(UTC)
Britt1
I don't know what is going on, because, the "standard ToolboxButtons" addin is there, and enabled, but it does not come in on the pulldown menu under insert.
Offline alyles
#14 Posted : 09 April 2019 23:42:14(UTC)
alyles
It may be necessary to restart SMath if you just installed Text Region Utilities.
Offline Britt1
#15 Posted : 09 April 2019 23:45:11(UTC)
Britt1
I installed it about 3 weeks ago, and have restarted the computer every day since.
#16 Posted : 10 April 2019 00:35:10(UTC)
"Standard Toolbox Buttons" is the built-in plugin that handles the callapsible palettes on the right of the screen (Arithmetic, Matrices, Booleans, etc...)
Text region Utilities is a different addin and provides (even) the "toolbox region".
If you search "text" in your extensions manager and you have the plugin installed you should see something like this (SS 0.99.7005):
Edited by user 10 April 2019 00:42:06(UTC)  | Reason: Not specified
Offline Britt1
#17 Posted : 17 April 2019 18:45:05(UTC)
Britt1
I have Text Region Utilities now. Is there a way to use search and replace to just search a selected portion of the worksheet, and not search the whole worksheet? Can I select a certain portion of the worksheet and have SMath search and replace for just the selected area?
#18 Posted : 18 April 2019 00:20:10(UTC)
Not as for now.
#19 Posted : 18 April 2019 03:24:59(UTC)
Something like in Google search reporting all Lagrange highlighted yellow
from some books in PDF ... thus reporting all regions containing Lagrange
in an Smath document. Or otherwise search for π in math regions ?
By portion: Do you mean page range of several pageswork sheet ?
or in displayed on screen ?
Long Smath work sheet of several pages are rare as they soon suffer
from shadow in context [dog chasing his own tail].
Guest (2)
Similar Topics
Find and replace? (Questions)
by fedeghi 12/10/2021 15:56:42(UTC)
Find and replacement (Feature Requests)
by netsonicyxf 30/01/2021 12:24:43(UTC)
Find and replace variables (Questions)
by Guest 18/01/2016 17:22:04(UTC)
