Offline Rosti
#1 Posted : 10 April 2019 09:54:52(UTC)
Rosti
I'm new to SMath. It's a great software but I'm frustrated with an (maybe simple) error.
I try to calculate a density wich follows a simple linear equation:
The equation is: D = 0,0006x+1
x stands for the mass.
Now I try to calculate the density with different masses:
How you see I can't solve the second equation with the unit "g". SMath shows "Unit don't match". I try different ways to insert units but it doesn't work in any direction.
So, what can I do? Where is the failure?
Thanks in advance for your help!
Offline PompelmoTell
#2 Posted : 10 April 2019 11:15:04(UTC)
PompelmoTell
The formulation you wrote for the density calculation (linear equation) would suggest a dimensionless formulation (those typical equations contained in technical manuals or codes). Therefore it must be used in dimensionless form with the quantities inserted without a unit of measurement. With m2 you have instead used a unit of measurement that caused the error by not being able to add up a dimensionless quantity (1) with a quantity with unit of measure (g)
Offline Rosti
#3 Posted : 10 April 2019 11:24:13(UTC)
Rosti
Thank you for quick reply!
I will calculate it dimensionless.
#4 Posted : 10 April 2019 11:32:30(UTC)
The 2 typical approaches; as said by Sergio the dimensionless operand drives the result:
https://en.smath.com/cloud/worksheet/3ecekeDo
Edited by user 10 April 2019 11:56:45(UTC)  | Reason: Not specified
#5 Posted : 10 April 2019 16:57:16(UTC)
Originally Posted by: Rosti Go to Quoted Post
So, what can I do?
... work Engineering/Scientific projects Unitless
Maths are unitless, so projects using maths.
IMHO, the attached is a good example.
Inst_Colebrook Pipe Data.sm (60kb) downloaded 19 time(s).
Offline Rosti
#6 Posted : 11 April 2019 08:49:20(UTC)
Rosti
Thanks for all answers! Good
#7 Posted : 11 April 2019 15:47:40(UTC)
Knowing in what units the document is designed/produced,
you can always append the unit in the result ... like this:
you can't define kg/m³:=1
otherwise kg_m³:=1
This SS 6179 should work in your latest SS version.
Inst_Type J Genfit Rational J_8.sm (97kb) downloaded 5 time(s).
