Offline Britt1
#1 Posted : 04 April 2019 22:15:41(UTC)
Britt1
How do you put in a header that automatically puts in the page number of the calculation you are on, in a multi page document?
Edited by moderator 05 April 2019 13:57:28(UTC)  | Reason: title edited - please don't write everything in capital letters
Offline mkraska
#2 Posted : 05 April 2019 01:33:06(UTC)
mkraska
Insert> Header and Footer (to enable them)
Insert> Field> Current page index (this can go to any math or text region in the header/footer)
Offline Britt1
#3 Posted : 05 April 2019 15:42:56(UTC)
Britt1
That works, for simple page numbering, but I wanted to say Page X of X and have the X's be automatic.
#4 Posted : 05 April 2019 15:53:59(UTC)
Simply add another field:
insert > field > Number of pages
Edited by user 05 April 2019 15:55:29(UTC)  | Reason: Not specified
Offline Britt1
#5 Posted : 05 April 2019 16:07:32(UTC)
Britt1
I figured out how to do that, but why is it so tedious. To do that, you have to put in the first number, then exit the command, come back in put in the word "of" then exit, and come back in and put in the number of pages, otherwise, it just changes the one box you are in, and it does not work. Seems like you should be able to put it in in one step.
#6 Posted : 05 April 2019 16:53:04(UTC)
Fields are a recent feature, they might be improved in future (a shortcut for the dialog, some sort of dynamic assistant, composed fields, an insert that doesn't close the dialog, ...). I agree it might be simplified, however isn't something you use massively in a document (you have to set it once per document or even less, if you prepare your own template to copy and use as starting point for every project).
Also, you can copy/paste this if you want:
Code:
page \[PAGENUM[0]]\ of \[COUNT[0]]\
on 06/04/2019(UTC)
Offline ElSid
#7 Posted : 15 November 2019 18:49:59(UTC)
ElSid
David,
I'm doing custom footers and inserted the Current Page Index (pagenum) field on the right hand side. How do I get it to start on page 3? I cannot find a way to edit this fields.
BTW; I have a LibreOffice cover sheet I want to use
Edited by user 16 November 2019 05:10:19(UTC)  | Reason: Not specified
Offline Kenny Lemens
#8 Posted : 01 April 2022 01:12:05(UTC)
Kenny Lemens
Was thanked: 62 time(s) in 39 post(s)
Greetings,
There is a simple solution, type the following:
Code:
page \[PAGENUM[2]]\ of \[COUNT[2]]\」
Your first sheet will start on page '3' and your total page number will be increased by +2
Similar Post: https://en.smath.com/for..._postst17506_Fields.aspx
-Kenny Lemens
