Hello SMath user, Plotting with Maxia doesn't work. Insert /Maxima/ 2D-3D plot results in an error message..: Cannot find the path (see appendix). In the German language the character o with arc does not exist. Here the path name contains the a with points ä . Can I use the Set path Are there other possibilities? Want to use Maxima plot not with 3DPlot. Thank you topsi
Normally the plugin should be unicode-proof. It uses SBCL. Does the plot work in wxmaxima?
