Offline Razonar
#1 Posted : 18 February 2019 19:13:53(UTC)
Razonar
Uruguay
This a solver for electrical circuits with the MNA method, here implemented as "stamps" for each linear circuit element. That's meaning that it's modular: can be extended adding more circuit elements stamps. To do: add nullors, diodes, transistors and describe how to handle subciruits.
mna_stamps.sm (406kb) downloaded 159 time(s).
thanks 4 users thanked Razonar for this useful post.
on 18/02/2019(UTC),  on 18/02/2019(UTC),  on 19/02/2019(UTC),  on 19/02/2019(UTC)
Offline Razonar
#2 Posted : 19 February 2019 08:08:39(UTC)
Razonar
Uruguay
on 19/02/2019(UTC)
Online alyles
#3 Posted : 19 February 2019 21:48:51(UTC)
alyles
Alvaro,
Awesome work! I'm excited to start using this. I see a lot of potential uses. I did have a question regarding your algorithm. In the attached segment, what is the purpose of repeating the for-loop inside the if/else condition on the right? I get the purpose of the for-loop to select the correct Stamp prefix, but do not see the benefit of added if/else on right side.
Thanks,
alyles
thanks 1 user thanked alyles for this useful post.
on 28/02/2019(UTC)
Offline oscampo
#4 Posted : 20 February 2019 01:16:17(UTC)
oscampo
Colombia
Was thanked: 87 time(s) in 66 post(s)
Nice work! and thanks for the use of one of my very old posts!!Clap
thanks 1 user thanked oscampo for this useful post.
on 20/02/2019(UTC)
Offline Razonar
#5 Posted : 20 February 2019 02:59:27(UTC)
Razonar
Uruguay
Originally Posted by: alyles Go to Quoted Post
Alvaro,
Thanks,
alyles
Hi alyles. Thanks for your words. As you say, the first loop it's for choose the correct Stamp with the first circuit element letter. The if ensure that if the string is largest than one, then can take a substring largest, but there are a bug there: must to be substr(str#, 1, 2), for make avaible the use of two letters too as stamp identifier.
Offline Razonar
#6 Posted : 21 February 2019 03:10:36(UTC)
Razonar
Uruguay
Hi. In the attached, bug about selecting stamps pointing by alyles not "corrected" but just eliminate the second loop. Also shows how to work with a pulse train, choosing a true periodic laplace transform from the input signal, not only the transform that figures on the books.
opamp integrator.sm (317kb) downloaded 56 time(s).
opamp integrator.pdf (465kb) downloaded 55 time(s).
on 22/02/2019(UTC)
Offline Razonar
#7 Posted : 23 February 2019 12:15:39(UTC)
Razonar
Uruguay
Hi. In the attached, bug for selecting stamps corrected. Also frequency domain analysis tools for use with MNA analysis: BodeMag, BodePhase, ZP Plot, Nyquist and Nichols charts.
mna_RLC_freq_domain.pdf (309kb) downloaded 63 time(s).
mna_RLC_freq_domain.sm (188kb) downloaded 51 time(s).
on 23/02/2019(UTC)
Offline - Norm -
#8 Posted : 27 February 2019 06:13:38(UTC)
- Norm -
Was thanked: 9 time(s) in 7 post(s)
Hello Alvaro, nice work!
I was planning to convert the attached (copy of) MathCad worksheet, but it seemed difficult for me. Would some of the routines, or stamps work in place of the solve block?
I welcome your review and look forward to your reply.
Sincerely,
Norm RLC step response - MC.pdf (696kb) downloaded 60 time(s).
Offline Razonar
#9 Posted : 27 February 2019 12:20:53(UTC)
Razonar
Uruguay
Hi Norm. Thanks. This is what think that you can do with the MNA method.
RLC Norma.sm (195kb) downloaded 52 time(s).
RLC Norma.pdf (176kb) downloaded 55 time(s).
#10 Posted : 27 February 2019 16:32:03(UTC)
If you can setup in form of DE [Differential Equation]
It will surely have a Laplace solution easy to extract.
Offline - Norm -
#11 Posted : 27 February 2019 18:58:20(UTC)
- Norm -
Many thanks Alvaro!
The "Thanks" icon presented an error.
Norm
#12 Posted : 27 February 2019 19:07:04(UTC)
This is a long lasting/reported bug.
Offline - Norm -
#13 Posted : 28 February 2019 00:43:59(UTC)
- Norm -
Thanks Jean, I'll try that as well... if I do it correctly.
Norm
#14 Posted : 28 February 2019 02:55:16(UTC)
Ifyou can setup in form of DE [Differential Equation]
The technical approach is simply write the Laplace algebra
of the circuit ... maple, bingo/done.
Literature call it H(s) ... I call it L(s).
You can find some examples browsing the web.
Those operational [symbol triangle] supplier
should give the L(s). Here is an old example.
Maths Laplace Circuit Algebra.sm (39kb) downloaded 53 time(s).
Offline - Norm -
#15 Posted : 25 March 2021 05:51:47(UTC)
- Norm -
Hello Alvaro, I hope you are well in this challenging time.
The MNA worksheet throws an error when I updated to version 0.99(build: 7610). It worked fine before then.
Here's the sheet:
RLC Norma.sm (195kb) downloaded 19 time(s).
The error:
Error.pdf (9kb) downloaded 11 time(s).
I welcome your review and recommendation(s) to repair the issue.
Stay safe and take care.
Sincerely,
Norm
Offline Razonar
#16 Posted : 25 March 2021 08:29:29(UTC)
Razonar
Uruguay
Hi Norm. Thanks for the good wishes. I hope you are well too. First issue is that new versions can't get the number of rows in the stamps matrix. So, change rows(E#) by it's value, 12.
That make almost all other calculus ok. But there are also a bug in SMath when when you invert matrices with units. For some reason, you must to change A#^-1 by maple(invert(A#)) for calculate the voltage in the first calculus with units (in this case for the current SMath can invert the matrix)
Now there are only one last red in a plot, but can't remember why is it.
RLC Norma.pdf (147kb) downloaded 27 time(s).
RLC Norma.sm (195kb) downloaded 40 time(s).
Finally, in the meantime I improve the Peaks function
MPeaks.sm (17kb) downloaded 32 time(s).
Offline - Norm -
#17 Posted : 25 March 2021 15:47:10(UTC)
- Norm -
Many thanks, for your prompt reply and fixes!
Sincerely,
Norm
Offline babElec
#18 Posted : 10 January 2022 15:37:52(UTC)
babElec
France
Really good job! I have to try it !! Kiss
thanks 1 user thanked babElec for this useful post.
on 10/01/2022(UTC)
