Sorry to be so slow on Smath. Some thing work like Mathcad and some don't. I need help with the correct syntax for the interpolation function linterp. I have tired all combinations of syntax that I can think of and none work in the attached Smath file. Help would be appreciated. RMD CALCULATION.sm (16kb) downloaded 24 time(s).
Joined: 23/03/2016(UTC) Posts: 278 Was thanked: 91 time(s) in 57 post(s)
I don't think vectorize works with this function. It is expecting a single value in argument 3. Checkout my linterp2 function in the attached. I think it does what you want. RMD CALCULATION.sm (19kb) downloaded 29 time(s).Note: In my program, it is not necessary to initialize the result. However, I have found that in cases of large vectors, it speeds up processing time to initialize a vector to the expected size and then fill in values. I generally just do this as standard practice now even if it's not necessary. Edited by user 15 February 2019 02:37:28(UTC)
Thanks much. You are a real help. I did not realize that the interpolation functions required additional programming. I incorrectly assumed it was like Mathcad. Many things are like Mathcad, but clearly not all. Thanks again. Reg
No problem!. Welcome to the forum. There are a lot of people here who are regular contributors and will help you with questions you have. For me, it's why I primarily use SMath for my calculations.
Regarding similarity/dissimilarity to MathCAD... once you start using SMath more you'll stop thinking in "MathCAD" and be able to think in "SMath". As a former MathCAD convert myself, I really started to come into my own when I stopped thinking of how I would do things in MathCAD and started figuring out how best to use SMath. |
Originally Posted by: Regulation Some thing work like Mathcad and some don't.I need help with the correct syntax for the interpolation function linterp. Read carefully: linterp, cinterp are 1/1 Mathcad Smath ainterp has special virtues not found in Mathcad. Smath linterp, cinterp, ainterp are 1/1 Mathcad as interpolation. but are 0/1 as scalar functions. In many instances, it is possible to recast the problem in the form of infinitesimal analysis. I found no way to render a_c_l interp scalar Mathcad style. Though, I have the Mathcad code. Don't confuse yourself, a_c_l_interp they plot on the canvas, i.e: they plot scalar. scalar is a kernel internal vanishing iteratorNext question: please attach the Smath document. Jean
Originally Posted by: Regulation Oops I meant this way to no success. Sorry, I downloaded the other one. Either blue/red will each have an extraordinary good model fit, for further processing [deriv, int].
RMD CALCULATION (J).sm (19kb) downloaded 15 time(s).
Jean, I appreciate your attempt at helping me. Unfortunately, I am new to Smath and don't really understand your syntax in your attached sm file. See my comments in the attached file. RMD%20CALCULATION%20(J)-1.sm (22kb) downloaded 13 time(s).Sorry, I am just too new to this code to appreciate your input. Thanks again, Reg
Joined: 28/08/2014(UTC) Posts: 1,371 Was thanked: 834 time(s) in 528 post(s)
Hi. You can do some plots too. Best regards. Alvaro. RMD CALCULATION.sm (11kb) downloaded 21 time(s).
Thanks to all. I was able to find some useful stuff from everyone. Here is where I was headed. RMD CALCULATION.sm (17kb) downloaded 15 time(s).
Originally Posted by: Regulation Sorry, I am just too new to this code to appreciate your input. Thanks again, Reg Hello Reg ... answered in blue RMD CALCULATION (J in_blue)-1.sm (25kb) downloaded 15 time(s).
Just a note. Pay attention to the plot by Alvaro. He uses often neded lele() function (Custom functions plugin) for checking if the value is in a range: Xmin<=x<=Xmax Regards, Radovan |
Originally Posted by: Regulation Thanks to all.I was able to find some useful stuff from everyone. ... more in there for publishing. Little Smath doing so much, so nice !Jean RMD CALCULATION (J).sm (36kb) downloaded 16 time(s).
Originally Posted by: Regulation Is this XY plot new?I find it really helpful. Not new, just from applied Smath features as in older SS 6179.
