Hey guys.
Maybe someone has a solution for next problem: I want to allow a user to receive bridge length by entering each span lengths separately. For example first of all I have variable N (span numbers) that tells me how many times I need to enter span length. I that possible?
Rank: Advanced Member Groups: Registered, Advanced Member Joined: 13/01/2012(UTC) Posts: 2,648 Location: Italy Was thanked: 1331 time(s) in 876 post(s)
Simplest way: With a more graphical approach, you can try with the modeller region. |
Wow, thats works just well. Thanks Edited by moderator 01 February 2019 13:05:45(UTC)
| Reason: marked as Solved
Originally Posted by: Eugene I want to allow a user to receive bridge length by entering each span lengths separately. click in front to add upstream click in back to add downstream click in front demonstrated only. So, you don't add separately, you select in group or individually at will
