In astronomy I need to use a symbol that looks like a circle with a dot in the middle as a subscript see luminosity formulas http://en.wikipedia.org/wiki/LuminosityIs there a plugin available with more symbols or can I somehow add more symbols. cheers Ivan
Rank: Advanced Member Groups: Registered, Advanced Member Joined: 13/01/2012(UTC) Posts: 2,648 Location: Italy Was thanked: 1331 time(s) in 876 post(s)
Originally Posted by: IAks In astronomy I need to use a symbol that looks like a circle with a dot in the middle as a subscript see luminosity formulas http://en.wikipedia.org/wiki/LuminosityIs there a plugin available with more symbols or can I somehow add more symbols. cheers Ivan Hi IAks, You don't need a plugin, just the right Unicode character (you can copy and paste the character from one site like Wikipedia, tamasoft.co.jp, alanwood.net or you can add the character holding the U and typing a #CODE# from the numpad) look the attachments regards, w3b5urf3r Edited by user 10 December 2012 18:25:16(UTC)
| Reason: Not specified File Attachment(s): Davide Carpi attached the following image(s): |
1 user thanked kilele for this useful post.
Joined: 01/08/2010(UTC) Posts: 115 Location: Rome Was thanked: 13 time(s) in 13 post(s)
Hi Davide sorry for the newbie question but how did you enter the the Sun Unicode character, I am trying to follow your suggestions without suceeding. What do you mean for holding the U and typing a #CODE# from the numpad. If I am holding U but the result is writing continuosly U on the canvas . I am trying to do the same using the Ctrl+K method but have the same result. The only way to make it work is with the copy and paste technique ... but it works only for one single unicode character in a variable name if I need to place 2 or 3 unicode characters close together it doesn't works ( better to say that I am not able to do this). To write Chemical concentration variables - that is the issue I am trying to address- for instance the concentration of [SO4]-2 I start from the superscript minus ( copy & past form a Unicode symbols page over Internet) then I add SO4 then I am not able to paste another unicode symbol for the superscript 2 , luckily exists the superscript 2 as an ALT sequence and so I was able to accomplish but if it was superscript 4 it was impossible (it doesn't exist an Alt sequence for it) . Thanks in advance for your help and best regards Franco Edited by user 07 November 2018 13:01:38(UTC)
I'm not sure why or how U+code was working in my previous Windows 7 OS... I'm aware that paste doesn't work in variable typing (you can only select a whole variable and replace it); as workaround you have to build the variable in a text/writer region (or notepad) and paste it. If you use writer region and you know the character code you can use CTRL+SHIFT+X (on hexadecimal code) / CTRL+SHIFT+D (on decimal code) Without cnversion, in any text editor/region you have to wrap the uppercase code in slashes All numbers are available as subscript/superscipt characters, although superscript 123 are in a different unicode block and might be rendered differently ( uniode superscript/subscript ). Edited by user 07 November 2018 15:27:53(UTC)
Originally Posted by: frapuano Thanks in advance for your help and best regards
Franco Maybe like this Franco ... Win 77 Charmap Arial
Hi. You can use this for not leave SMath and get the unicode chars that you want: UNICODE_VAR.sm (3kb) downloaded 24 time(s).Notice that you must to split the unicode char for preventing it substitution with the char itself when copy and paste the expression. Best regards. Alvaro.
... otherwise with great efficiency:
Originally Posted by: Jean Giraud ... from 6 years old .
Tentatively we can highlight a specific circular region. ... Not so much happy, but proved highlight a region.
