SMath Studio Forum
Bugs & Problems
"Plug-in(s) installation failed" error
Joined: 05/06/2014(UTC) Posts: 348 Location: Colombo Was thanked: 127 time(s) in 82 post(s)
The latest MapleWrapper plugin fails to install. Tried several clean installation of latest SS, but did not solve this problem. Edited by user 21 September 2018 20:05:19(UTC)
Hmm. I can't reproduce this issue. |
Again tried to install MapleWrapper, but same problem. Then I get another problem with WriterRegion. Some link???? The only way for me was to do a clean re-installation without trying to install MapleWrapper, and then WriterRegion can be installed. Any attempt to install MapleWrapper will trigger the same problem with WriterRegion. I don't know why? Edited by user 21 September 2018 21:02:31(UTC)
Try to remove SMath Studio and extensions manually. |
Yes I did it several times without success. Also pl see my edited post above. Edited by user 21 September 2018 21:07:29(UTC)
I deleted the new build. Try the previous version. |
Yes, it now works fine. Thank you. |
Rank: Advanced Member Groups: Registered, Advanced Member Joined: 13/01/2012(UTC) Posts: 2,652 Location: Italy Was thanked: 1339 time(s) in 878 post(s)
TextRegionUtilities might be involved in the issue? |
Very strange behavior. I made only small changes today and for me all works fine. |
The MapleWrapper new build works now. But see the following. Very strange. Cannot install TextRegionUtilities also, as indicated by Davide. Edited by user 21 September 2018 22:56:02(UTC)
1 user thanked ndtma for this useful post.
Attached file last opened and saved on 11/09/2018, but now fails due to MathcadFileAccess plugin failing to install. P_day_Avg & P_day_Mov. Avg.sm (38kb) downloaded 11 time(s). |
Forgot to attach the Excel file. Extremely Sorry. 1.July WL&RT.xlsx (242kb) downloaded 10 time(s). |
I think only Andrey can help here. Something wrong with your environment. |
I've tried several combinations but I'm unable to reproduce as for now. If you rename the "SMath" folder contained in %APPDATA% into something else and then you reinstall the extensions the issue still appears? P.S. moved the messages here since it seems not related with a specific plugin. Edited by user 22 September 2018 20:34:21(UTC)
Thank you Davide. Your suggestion worked fine, with all necessary plug-ins installed, and all the programs running smoothly.
Also thank you uni, for all the encouragements. |
Hello.
I'm aware about this issue. It happens only in the following case: 1) New version of SS released; 2) New version of the plug-in for latest SMath Studio released; 2) New version of the plug-in for old version of SMath Studio released.
In this case there are couple of issues happens on server side which breaks behavior of the Extensions Manager.
It is absolutely clear how to fix this, but it requires a time. I plan to address it as soon as possible.
As for today new stable version of SMath Studio released and if you'll find any issues with plug-ins installation just rebuild and publish plug-ins for this latest version. Issue will gone.
on 23/09/2018(UTC), on 23/09/2018(UTC)
Originally Posted by: uni I think only Andrey can help here. Something wrong with your environment. I believe the reason for failure to install plug-in(s) was an Antivirus Program (NOT Kaspersky). After successfully installing latest SS "0.99.6839.38235" with necessay plug-in(s), problems cropped up again with CephesMathematicalLibrary, MapleWrapper, ODESolvers and a few. I had to struggle to configure the Antivirus package to prevent blocking installing above plug-in(s). Now SS is working without any apparent hassle. Edited by user 23 September 2018 10:39:32(UTC)
2 users thanked ndtma for this useful post.
I have the same problem with the Smath update, but with Excel plug-in. Smath version: 0.99.6839 EXCEL I/O with recalculation and PNG export version: 1.99.6354.6352 Edited by user 03 October 2018 15:27:42(UTC)
Originally Posted by: Antoniobmg I have the same problema with the Smath update, but with Excel plug-in.
Smath version: 0.99.6839 EXCEL I/O with recalculation and PNG export version: 1.99.6354.6352 Yes, I too get this error. But, all efforts to configure the Antivirus package failed. I do not know whether changing the Antivirus program will solve this. Somebody may be able to help you. Sorry. I am using a paid version of the Antivirus. Edited by user 27 September 2018 20:20:18(UTC)
Smath version: 0.99.6839 EXCEL I/O with recalculation and PNG export version: 1.99.6354.6352 This is not one of the cases above. That plugin isn't updated to the latest API, hence it fails to install (in the extension page you can see that the latest version was released at 2017-05-25) |
SMath Studio Forum
Bugs & Problems
