Updated. al_nleqsolve() refactored. Try now. You can also specify only names of the systems ( f and j). Edited by user 18 July 2018 06:39:19(UTC)
4 users thanked uni for this useful post.
on 18/07/2018(UTC), on 18/07/2018(UTC), on 18/07/2018(UTC), on 18/07/2018(UTC)
Joined: 15/07/2010(UTC) Posts: 437 Location: Beer-Sheva Was thanked: 520 time(s) in 288 post(s)
One example of V. Mezentsev (Uni) Primer Uni.sm (14kb) downloaded 61 time(s).Edited by user 27 July 2018 16:37:57(UTC)
2 users thanked Ber7 for this useful post.
Originally Posted by: Ber7 One example of V. Mezentsev (Uni) Primer Uni.sm (14kb) downloaded 61 time(s). Fortunately, I was wrong. We could use it with different number of equations and unknowns. I just use the Ber7 example and change it with n as a global variable. No need for zeros as non-existing functions. Primer%20Uni-mod.sm (14kb) downloaded 57 time(s). |
Thanks a lot uni! The issue listed in my post #18 has been resolved. But for some reason simple Newton-Raphson with variable step usually works better than al_nleqsolve.
Originally Posted by: tomtit But for some reason simple Newton-Raphson with variable step usually works better than al_nleqsolve. Can you demonstrate for this application ? Solve al_nleqsolve-Electron.sm (19kb) downloaded 44 time(s).
1 user thanked Ber7 for this useful post.
3d.sm (30kb) downloaded 53 time(s).Edited by user 27 July 2018 16:35:26(UTC)
on 22/07/2018(UTC), on 22/07/2018(UTC)
Thanks Ber7 for the 3D, nice.
The process of finding the roots Primer Anim.sm (31kb) downloaded 49 time(s).
on 22/08/2018(UTC), on 22/08/2018(UTC)
Simple solutions to two problems1.The construction of a sphere with respect to four given points 2.The construction of a circle with respect to three given points To calculate the coordinates of the center and radius using the solver AlgLib In the first problem, a system of four sphere equations for four given points is solved. In the second - a system of three equations of a circle and the equation of a plane for three given points. SphereAlglib.sm (65kb) downloaded 45 time(s).
Hi. The same, but without plugins. SphereSMath.sm (76kb) downloaded 46 time(s).Best regards. Alvaro. PD: Do you know the angles for your rotation matrix gamma? I get this, but can't put the matrix elements in the correct order nor sign: Actually, as I know, the minus in the last atan is a mistake, but at least give the same absolute values.
on 08/10/2018(UTC), on 08/10/2018(UTC)
Actually, as I know, the minus in the last atan is a mistake, but at least give the same absolute values. Hi, Alvaro. Unfortunately, I have never done reverse transformations (gamma-omega). Your error may be caused by the use of the left coordinate system in Smath- graphs. I selected the angles for the axial matrices empirically in order to get a good perspective ,using the gamma matrix.perspective.
Originally Posted by: Ber7 Unfortunately, I have never done reverse transformations (gamma-omega). Mathcad solves the Euler angles from a given γ [gamma matrix]. Smath does not immediately, it complains: Try to use a more specific algorithm. There are 24 [4!] possible ways to define a 3D system [Mathematica]. The most common is Euler though Mathcad Mathcad ≠ Mathematica. For common use to define some pleasant views, especially in Smath: 1. Euler [ 3 trig angles] 2. Parametric [X,Y,Z,t] very easy to manage. 3. Quaternion only two coefficients that Quaternion solves for the 3D γ matrix Rotate Horn.sm (16kb) downloaded 50 time(s). Solve Euler Fails.sm (23kb) downloaded 43 time(s). Rotate Breather [Euler].sm (38kb) downloaded 42 time(s). Rotate_0 Euler, xyz(t), Quaternion.sm (276kb) downloaded 46 time(s).
Updated. Changes for al_rkckadapt(): - zero point issue fixed; - added support for the simple D(t,x) definition. Edited by user 12 December 2018 19:28:27(UTC)
on 12/12/2018(UTC), on 12/12/2018(UTC)
