Joined: 28/08/2014(UTC) Posts: 1,359 Was thanked: 818 time(s) in 518 post(s)
Hi. I can not understand why the argument of the last function "disappears" Thanks in advance Alvaro. dec2hex bad.sm (26kb) downloaded 22 time(s). dec2hex bad.pdf (208kb) downloaded 14 time(s).
Rank: Advanced Member Groups: Registered, Advanced Member Joined: 13/01/2012(UTC) Posts: 2,652 Location: Italy Was thanked: 1339 time(s) in 878 post(s)
The answer is in dec2bas(x,b). In the third row there is x:(x-m)/b; arguent:something inside the function is a pass-by-reference operation from the function to the argument, hence the behavior (900 becomes 0). If you don't want it, assign x to an internal variable and do all the definition operations on that variable (f.e. z:x -> z:(z-m)/b) Edited by user 24 August 2018 02:51:59(UTC)
| Reason: marked as SOLVED |
If you don't want it, assign x to an internal variable and do all the definition operations on that variable (f.e. z:x -> z:(z-m)/b) Tante grazie Davide! I did not know where else I could look for the error, because I thought I had reviewed everything. Best regards. Alvaro.
