Offline Speedracer
#1 Posted : 02 August 2018 12:20:49(UTC)
Speedracer
Uzbekistan
How to make the program use MPa instead of Pa in the formula?
1.sm (11kb) downloaded 23 time(s).
#2 Posted : 02 August 2018 17:50:30(UTC)
Engineering formulas should be unitless, as is from books.
In the empty place holder of Q, paste MPa from user unit.
Offline mkraska
#3 Posted : 02 August 2018 20:15:53(UTC)
mkraska
The topic starter has used units just the way it is efficient in SMath Studio. Write a formula as found in a book, define the quantities using the given units and get the result in the correct dimension.
If you don't like the default unit, you can change the display easily.
Go to the unit placeholder and type the desired result there. The dynamic assistant will help with a list of known items. In the given case it is sufficient to type MP and then TAB to confirm the selection in the list.
Read more on this in the "Units of measurement" branch of the Interactive handbook.
Offline Speedracer
#4 Posted : 03 August 2018 11:43:39(UTC)
Speedracer
Uzbekistan
The program does not use the number I need.
if I choose "Ignore units" the program solves correctly
#5 Posted : 03 August 2018 13:16:12(UTC)
Often these types of formulas are made to be used with specific units as input... my thought is that the 10^6 used in the denominator is specifically provided to use P.a in MegaPascal as input, while the program uses the base units (the ratio under the arrow has P.a in either numerator and denominator, thus the magnitude doesn't matter here, unless you provide P.пр and P.a with wrong relative magnitude)
Edited by user 03 August 2018 13:44:40(UTC)  | Reason: typo
