on 02/08/2018(UTC), on 02/08/2018(UTC)
Originally Posted by: uni Simple test 2. Works nice conventional/visual [6179]. That document, if it would come from other designer would pass my QA [Quality Assurance]. Jean DotNumerics.ode.test2.sm (25kb) downloaded 36 time(s).
Joined: 15/04/2012(UTC) Posts: 1,988 Was thanked: 1127 time(s) in 723 post(s)
It seems that all the dotnumeric ode solver functions fail to add the last step to the solution. In the given example, the exact solution is (approximately) met if the end value of x is increased by one step (x_end/steps). The sheet is easily extended to whatever ode solvers by adding their name to the search list. The actually available solvers depend on what plugins are installed. Section Math ODE precision.sm (24kb) downloaded 56 time(s). |
2 users thanked mkraska for this useful post.
on 09/09/2018(UTC), on 10/09/2018(UTC)
Updated for SS 0.99.6824. Intervals issue fixed. |
on 10/09/2018(UTC), on 10/09/2018(UTC), on 10/09/2018(UTC)
Updated.
Changes: - zero point issue fixed; - added support for the simple D(t,x) definition. |
4 users thanked uni for this useful post.
on 24/12/2018(UTC), on 24/12/2018(UTC), on 24/12/2018(UTC), on 24/12/2018(UTC)
Native works as well. You can try rkfixedSteven.
Plugin updated. Changes: - added support the mathematical form of the problem for ODE solvers; - refactored. |
Plugin updated. Changes: - solution restructured; - converting the task for the ODE solver to the numerical form is now performed through the Mathcad Toolbox plugin (to avoid code duplication), so it must be installed; - refactored. Solvers that support mathematical notation now reuse code from the Mathcad Toolbox plugin. Now there is no need to recompile every such plugin. |
Joined: 28/08/2014(UTC) Posts: 1,357 Was thanked: 815 time(s) in 516 post(s)
Hi Viacheslav. There are an issue with Implicit and dn_ExplicitRK45, just in the first element. Please see the attached. dn_ExplicitRK45 issue.sm (9kb) downloaded 10 time(s).Best regards. Alvaro.
Plugin updated. Changes: - fixed values of initial conditions in the output array for dn_ImplicitRK5() and dn_ExplicitRK45(). |
on 22/08/2022(UTC), on 24/08/2022(UTC)
