Offline Geoffdb
#1 Posted : 27 July 2018 14:32:00(UTC)
Geoffdb
Rank: Member
New Zealand
I've just recently become aware of this excellent product .. on many fronts .. and so am looking to use where I work.
However, I have two questions, related to implementing headers.
1) Background image : is there any way to make this fill the whole page, even when eg the top margin is set to, say 40mm ? As far as I can tell, whenever the page printable area is reduced it also reduces the background image size (which I was trying to use as a header)
[ I'll keep the second question in a separate stream, for simplicity. Also, apologies for posting in the Shoutbox .. my mistake as am just new to this .. please feel free to delete them ]
I'm using version 0.99 (build 6671)
Thanks, Geoff
Edited by user 27 July 2018 14:37:06(UTC)  | Reason: Not specified
#2 Posted : 29 July 2018 02:28:18(UTC)
This a generalized/personalized Cartouche. Little modifications will make for my all project.
Some project will have 100's Instrument Spec Sheets, [Temperature, Pressure, Flow, Valves ...]
With a bit of patience they can be resumed in Data Table c/w more pertaining information(s).
This last type of document [Data Table] is so huge that it was done on Drawing size.
Offline Geoffdb
#3 Posted : 31 July 2018 01:23:22(UTC)
Geoffdb
Rank: Member
New Zealand
Thanks for this .. but this is simply images on the first page, right ?
The aim is to have a header, ideally 'pre-populated', at the top of every page.
Thanks, Geoff
#4 Posted : 31 July 2018 04:39:45(UTC)
Two things:
1. The logo is an image, i.e: your Company Logo but the text is as per project.
2. The header is roughly from Windows and in Smath can't be redesigned.
You would need a plugin, completely useless as you just have to use your template
for each documents. I have recollection some Engineering firm using such
model template, for their Mathcad documents purported to Clients.
Offline Geoffdb
#5 Posted : 01 August 2018 13:27:14(UTC)
Geoffdb
Rank: Member
New Zealand
Thanks Jean
I thought so, but wanted to acknowledge your contribution, thank you. I am also following up a related question in another strand.
Thanks
Geoff
