First of all, I apologize to you for my english.
I found Smath some days ago and i am testing it. It's seem as a very good soft. But during my tests, I am confronted with some questions without being able to find answers.
Those questions are:
1. Is it possible to change the axis names (in fact, i want to make a diagramme for the pression evolution from volume and view an axis for the pression axis and an axis for the volume)
2. How can i do a différent zoom on axis (sample : showing x between 0 - 10 and y between 0 -12000)
Thanks for help
Originally Posted by: codesite 1. Is it possible to change the axis names (in fact, i want to make a diagramme for the pression evolution from volume and view an axis for the pression axis and an axis for the volume)
2. How can i do a différent zoom on axis (sample : showing x between 0 - 10 andy between 0 -12000)
Thanks for help Please, attach your pressure evolution function as you have it. This will help to doctor or otherwise propose alternatives. Jean
Joined: 10/12/2009(UTC) Posts: 249 Location: Cali, Colombia Was thanked: 87 time(s) in 66 post(s)
Thanks for help Hi, Maybe you need something like this?: The file to do this is here: Pressure Evolution.sm (4kb) downloaded 15 time(s).you can use with your own data Regards!!
File with explication : pressure.sm (28kb) downloaded 28 time(s).i hope that it's more clear.
Originally Posted by: codesite File with explication : pressure.sm (28kb) downloaded 28 time(s).i hope that it's more clear. It is a bad idea to have variable with units to a noninteger power. Do not use units in this example. Regards, Radovan |
Originally Posted by: codesite File with explication : That one was missing in my collection. Just remade quick. Thanks Collab ... Jean Inst_Pressure Gradient.sm (21kb) downloaded 25 time(s).
Originally Posted by: codesite File with explication : pressure.sm (28kb) downloaded 28 time(s).i hope that it's more clear. Your file in a simple way... pressureSimple.sm (8kb) downloaded 20 time(s).
Originally Posted by: Jean Giraud Thanks Collab ... Jean P.a is 1x10^5. You used 1 Never mind. P.b is missing it too. you scaled it back in the math ... Edited by user 13 July 2018 04:55:35(UTC)
| Reason: Not specified
Originally Posted by: ElSid Never mind.P.b is missing it too.you scaled it back in the math ... Sometimes, transmission damages document. here is again. Inst_Pressure Gradient.sm (22kb) downloaded 23 time(s).
Thanks for your helping
My problems are solved
Originally Posted by: codesite Thanks for your helping
My problems are solved If that one can be of any use. Inst_Isentropic Discharge.sm (176kb) downloaded 18 time(s).
