Offline PDG
#1 Posted : 16 June 2018 21:43:24(UTC)
PDG
Rank: Member
Norway
Was thanked: 4 time(s) in 3 post(s)
I found small bug in Differential Equations Display.
Simple example:
Calculations are done. But symbolic evaluation do not show the outcome.
The problem is not catastrophic. But I thought it worth it to report it.
#2 Posted : 17 June 2018 03:59:33(UTC)
Confirmed: no bug ... your screen is lazy to expand ... if that what you have !
Offline PDG
#3 Posted : 17 June 2018 12:58:08(UTC)
PDG
Rank: Member
Norway
Jean, you misunderstood the "problem".
Not the calculation is wrong.
This is:
As I wrote, it is not big and not a kind it is impossible to live with it.
I am just reporting what I notice.
#4 Posted : 17 June 2018 16:32:25(UTC)
There is no use to evaluate the Mathcad style. On the other hand,
many direct expansion Mathcad style can't be copied for export.
Thus, the best is the algorithmic construction. On that point,
Smath is fully competent ... look @ the "Colibri" attached.
Spline De Boor [Colibri].sm (35kb) downloaded 16 time(s).
#5 Posted : 18 June 2018 00:31:04(UTC)
There are few more curiosities in Smath.
In Smath, erf(x) is not a scalar function in the maths sense,
Build the example
and if you get the two red ones, "X-not defined"
that you must read "erf(x) is not scalar" ... Thus:
1. vectorize the integrand
2. Pre-assign the X_Y plot
Example from version 6179
Offline Andrey Ivashov
#6 Posted : 18 June 2018 00:53:50(UTC)
Thank you, PDG Offline .
Bug confirmed. Will look at it later.
Offline PDG
#7 Posted : 18 June 2018 01:08:08(UTC)
PDG
Rank: Member
Norway
I thank you Andrey.
I use SMath almost 10 years now.
Univ., Research, PhD, now at side projects.
Great tool. Great work.
#8 Posted : 18 June 2018 02:31:41(UTC)
That one, X_Y refuses plotting at all !
#9 Posted : 18 June 2018 05:23:28(UTC)
I accept, but in turn you must accept the fundamental
concept of transit algorithm in integration/derivation.
Good thing it is this way, otherwise lot more advanced maths
could not be done or would issue errors messages of all kinds.
... light red page 4.
Maths_0 Transit [The concept].sm (77kb) downloaded 12 time(s).
#10 Posted : 18 June 2018 05:53:48(UTC)
transit algorithm
... this is another style of parametric solution.
ODE_Laplace 1rst [Type 1].sm (25kb) downloaded 13 time(s).
#11 Posted : 18 June 2018 06:32:23(UTC)
... a much different style of transit.
At that times my brain diluted on that one !
Takes quite a while before "t_not defined"
Integrate Voltera IntEQUATION.sm (29kb) downloaded 19 time(s).
