Joined: 23/03/2016(UTC) Posts: 277 Was thanked: 91 time(s) in 57 post(s)
I have attached a small script for creating logranges. These can be useful for numerically evaluating functions of frequency. I hadn't yet found a built in SMath function that does this, so I made one myself. It works for my purposes. It may not be the best algorithm/method so feel free to critique/improve. logrange.sm (11kb) downloaded 37 time(s).. |
Originally Posted by: alyles It may not be the best algorithm/method so feel free to critique/improve. Work sheet is empty , mon ami !!!
Originally Posted by: Jean Giraud Work sheet is empty , mon ami !!! Hmm. I just downloaded it and it opened ok. Anyone else have this issue? |
Joined: 05/06/2014(UTC) Posts: 348 Location: Colombo Was thanked: 125 time(s) in 82 post(s)
Downloaded successfully and opened. No issues. |
Rank: Advanced Member Groups: Registered, Advanced Member Joined: 13/01/2012(UTC) Posts: 2,648 Location: Italy Was thanked: 1331 time(s) in 876 post(s)
Originally Posted by: Jean Giraud Work sheet is empty , mon ami !!! Not empty but I confirm that doesn't open correctly in 0.98.6179 (to investigate) Works fine with latest stable. This should works for you Jean. logrange_0_98_6179.sm (11kb) downloaded 17 time(s).Edited by user 24 May 2018 22:25:37(UTC)
Added a second logrange2() function. First function was linear within each decade. logrange2 remains logarithmic (linear in log domain) throughout. I could see applications where either might be appropriate. logrange2.sm (14kb) downloaded 19 time(s).Edited by user 25 May 2018 21:01:56(UTC)
Originally Posted by: alyles I could see applications where either might be appropriate.
What could be wrong, Your attachment does not include the demo plot ? Just posted "log10 spaced stem" [Samples].
