Offline yuriy1996
#1 Posted : 18 May 2018 16:05:41(UTC)
yuriy1996
Rank: Member
Ukraine
I have one formula where it is necessary to make a sum in a way that takes into account 5 coefficients of a polynomial. In the sum he is marked as ak and I need that instead of ak there was a1..a2..a3 ... a4 ... a5. Also, for each polynomial account, the power K automatically changes from the index of the polynomial 1..2..3..4..5. How to implement it in this program? Also, I have several layers of reinforcement in the equation that should also be instead of Asi to As1...As2...As3...Asn and Sigma_si to Sigma_s1...Sigma_s2...Sigma_s3...Sigma_sn . Sorry for bad English.
Arkush1.sm (12kb) downloaded 14 time(s).
Offline PompelmoTell
#2 Posted : 18 May 2018 16:32:44(UTC)
PompelmoTell
You made the following error: you used "a.k" instead of "a[k". This way you did not create vectors to use in the summation with the counter. You need to do to define and then use As and Sigmas.
on 18/05/2018(UTC)
Offline yuriy1996
#3 Posted : 18 May 2018 16:38:06(UTC)
yuriy1996
Rank: Member
Ukraine
I corrected a.k for a[k but how do I set 5 values for one variable a[k?
#4 Posted : 18 May 2018 16:55:32(UTC)
PompelmoTell
for example a[1:=2.5 a[2:=3.21 a[3:=-7.1
so "a" is a vector
in the sum a[k
on 18/05/2018(UTC)
Offline yuriy1996
#5 Posted : 18 May 2018 17:13:48(UTC)
yuriy1996
Rank: Member
Ukraine
Unable to determine the value of an element since the item with the specified index does not exist -error
Offline yuriy1996
#6 Posted : 18 May 2018 17:16:25(UTC)
yuriy1996
Rank: Member
Ukraine
Arkush1.sm (15kb) downloaded 14 time(s).
Offline CBG
#7 Posted : 18 May 2018 17:46:35(UTC)
CBG
Solution
Arkush1_CBG.sm (16kb) downloaded 20 time(s).
Carlos
thanks 1 user thanked CBG for this useful post.
on 18/05/2018(UTC)
#8 Posted : 18 May 2018 18:29:55(UTC)
... you may clean/recast a bit.
Arkush1_CBG.sm (14kb) downloaded 18 time(s).
#9 Posted : 18 May 2018 19:18:18(UTC)
You have 11 sets of 'a'
Easy to tabulate, is it what you want ?
Offline ndtma
#10 Posted : 18 May 2018 19:51:50(UTC)
ndtma
Sri Lanka
Was thanked: 127 time(s) in 82 post(s)
Pl look at this. Error may have occurred when entering the formula???? Difficult to trace.
Unable to select individual components of the erroneous formula.
Arkush1_ndtma.sm (17kb) downloaded 15 time(s).
Edited by user 18 May 2018 20:09:30(UTC)  | Reason: Not specified
#11 Posted : 18 May 2018 20:53:49(UTC)
Arkush1_CBG [data].sm (137kb) downloaded 22 time(s).
#12 Posted : 19 May 2018 03:34:10(UTC)
There it seems the formula is ill posed wrt [4.1].
It shows bfcd as something not defined but the originator
has defined b, and defined fcd ... b*fcd.
