SMath Studio Forum
Questions
How to choose the maximum value from the formula?
I need to recreate the formula for determining the minimum protective layer of concrete. In the formula there is a choice of the maximum value in curly brackets. How do I use this program to make the minimum protective layer of concrete equal to the maximum value in a curly bracket and greater than or equal to 10 millimeters.
c_min=max{c_min,b;c_min,dur+c_dur,y-c_dur,st-c_dur,add}>=10 mm
In fact, it would be advisable to send the sample sheet. Something is not convincing (the braces in Smath are not used). However, the "max" function provides for evaluating the maximum value of a vector internally; then you can put in a vector all the elements to choose the maximum (including "10mm" . Alternatively, the "Max" function contained in the "Custom" plugin (you have to install it from a special menu) directly accepts the lists. sergio
2 users thanked PompelmoTell for this useful post.
on 17/05/2018(UTC), on 17/05/2018(UTC)
Min/Max ... for Matrices/Vectors min/max ... for functions in matrices/vectors Sample attached to illustrate min(vector of functions) 2D Plot Discontinuous [min(,)].sm (15kb) downloaded 52 time(s).
SMath Studio Forum
Questions
