Joined: 15/03/2018(UTC) Posts: 23 Location: Hamilton Was thanked: 1 time(s) in 1 post(s)
Hi All, I have created an equation and waveforms. I was trying to integrate the waveform but am not getting the expected answer. The period of the waveform is 0.0166 sec. the expected answer is 0.300 A I am attaching HWRL.sm (12kb) downloaded 24 time(s). the file HWRL.sm (12kb) downloaded 20 time(s).Regards, Vijay
Originally Posted by: Vijay I have created an equation and waveforms. I was trying to integrate the waveform but am not getting the expected answer. 1. adjust the period from the tentative attached. 2. The integrator is a scalar integrator, but you have a discrete set. 3. If you want to know the area under the curve, then use finite differences method in two segments. HWRL[1].sm (14kb) downloaded 26 time(s).
