2 Pages12>
Offline MarB
#1 Posted : 29 April 2018 21:11:33(UTC)
MarB
Shouldn't the variable A be replaced by its value 1 when 'cases' is used instead of 'if/else'?
thanks 1 user thanked MarB for this useful post.
on 30/04/2018(UTC)
#2 Posted : 30 April 2018 02:02:30(UTC)
Whatever is behind the scene, your project is ill posed..
Conditional statements must be intelligible for the numerical maths.
Offline MarB
#3 Posted : 30 April 2018 09:43:25(UTC)
MarB
I really don't want to play silly games with you anymore.
I asked a simple question: "Why is the value of the canvas variable A not stored in the function, when cases is involved?"
Your answer has absolutely nothing to do with my question.
I have attended another screenshot to show the consequences of not storing the value.
cases behaves, as if there where a line operator.
cases.sm (10kb) downloaded 24 time(s).
#4 Posted : 30 April 2018 14:47:02(UTC)
I notice one instance if/otherwise does not work vs if/else.
Reported, not acknowledged ... maybe more than one instance.
#5 Posted : 30 April 2018 16:17:16(UTC)
... generally, if/else is more convenient in program.
Utilities Matrix Exclude Region.sm (36kb) downloaded 21 time(s).
#6 Posted : 30 April 2018 16:41:02(UTC)
... refreshed
Utilities Matrix Exclude Region.sm (42kb) downloaded 20 time(s).
#7 Posted : 30 April 2018 17:20:30(UTC)
... ill posed code don't speak, rather crash the project.
Glance for De Boor in Samples,,, will be pleased to re-post.
Offline alyles
#8 Posted : 30 April 2018 21:12:40(UTC)
alyles
Davide can answer this for certain. However, I would imagine that it should not. Since cases() function is kind of like a wrapper for nested if() statements, I imagine that it stays completely symbolic until evaluated numerically.
This is just a guess. Otherwise I would imagine that when you evaluated a cases() statement symbolically you would see the nested if() instead.
Offline MarB
#9 Posted : 30 April 2018 22:23:02(UTC)
MarB
Originally Posted by: alyles Go to Quoted Post
... However, I would imagine that it should not. Since cases() function is kind of like a wrapper for nested if() statements, I imagine that it stays completely symbolic until evaluated numerically.
The two expressions in the screenshot in my first post are evaluated symbolically.
I think I can remember that in the past when "hovering the mouse" it was was dissolved in a chain (product) of boolean expressions, without using if/else.
Offline alyles
#10 Posted : 30 April 2018 22:30:39(UTC)
alyles
Yes, It looks like that may have changed about two years ago according to this post: https://en.smath.info/fo...ns-plugin.aspx#post35489
Which leads me to believe the cases() functions worked different depending on the optimization.
You can see source code here: https://smath.info:8443/!/#public/view/head/plugins/CustomFunctions/SMathFunctions/Programming/cases.cs
I'm not well versed enough in plugin creation to know how this is handled with different optimizations.
Offline alyles
#11 Posted : 30 April 2018 22:40:48(UTC)
alyles
I suppose what it comes down to is how input variables are passed to a function defined in a plugin and when they are evaluated w.r.t. the different optimization options.
#12 Posted : 30 April 2018 23:05:02(UTC)
Can't be evaluated otherwise => nothing is defined/assigned,
thus literal evaluation ... try this
Maybe you missed my other point about appropriate condition [De Boor]
You have that in much simpler instances, not visible and falsifying project.
Offline MarB
#13 Posted : 30 April 2018 23:28:50(UTC)
MarB
The values of a, b and q(x) are not stored in f, as you can see in the following screenshot.
And by assigning f to f they are!
And that seems to me like a kind of invisible line operator, because it behaves like one.
Offline ElSid
#14 Posted : 30 April 2018 23:43:56(UTC)
ElSid
Have you tried programing it? Use line in lieu of the system of values or equations bracket?
Offline CBG
#15 Posted : 01 May 2018 00:11:39(UTC)
CBG
by--->MarB
I do not understand. The cases function works perfectly.
cases_ok.sm (5kb) downloaded 17 time(s).
Carlos
#16 Posted : 01 May 2018 00:46:22(UTC)
The all thing is about what comes from conditional.
For instance: the integration operator needs an analytical integrand.
From if/else, integrand is not scalar vs if/Otherwise.
Simple things turn nightmare ... many same in Mathcad.
Plots are same but not integration.
#17 Posted : 01 May 2018 02:14:58(UTC)
... for this particular integration example, it is necessary and sufficeinet
to transform the domain of if/else [ infinitesimal ...] in scalar domain.
Here, we have it already done in term of integration.
Integrate Discontinuous [Nuance].sm (14kb) downloaded 16 time(s).
Offline alyles
#18 Posted : 01 May 2018 16:04:25(UTC)
alyles
The difference comes when the value of A changes after the definition of f(x) and g(x).
For g(x) the original definition of A:=1 remains. However, for f(x) the value of A changes.
cases_ok_alyles.sm (6kb) downloaded 20 time(s).
Offline alyles
#19 Posted : 01 May 2018 23:53:43(UTC)
alyles
So I believe I understand what is going on a little better.
I've attached the same .sm file as before only this time with break points. If you open the debugger window and step through you can see exactly what happens.
When f(x) is defined it sets f(x) equal to cases(a,x<A,b ), which is essentially the function call of cases(). But it does not further evaluate cases() or or it's input variables.
Note when g(x) is defined it will step through and evaluate the if() function and each individual input parameter (x<A,a,b ).
The cases() function within f(x) doesn't actually evaluate until it is called with f(0).
This is why, as you described earlier, if you set f(x):=f(x) you finally get the result that you want, because at this point it will finally evaluate cases(a,x<A,b ).
I'm not sure if this is a plugin issue or if this is just how SMath handles it's plugin interface.
cases_ok_alyles_with_breakpoints.sm (6kb) downloaded 19 time(s).
#20 Posted : 02 May 2018 00:51:59(UTC)
This type of maths is universal and maybe centuries accepted,
and a rigorous rule since numerical computing machinery.
Just like this.
Guest (2)
2 Pages12>
