SMath Studio Forum
Questions
Making Vector Elements Cumulative
Joined: 04/12/2017(UTC) Posts: 61 Was thanked: 2 time(s) in 2 post(s)
In the attachment at the start of Page.5 I (so far) am unable to construct a loop or something that cumulatively adds vector elements down the column. So I am manually doing this for now, any ideas? I have started additions from the 6th element because first x4 were zero ...but I think you get the idea! https://imgur.com/7KSBDM8Secondly in the last page there is a 2D-graph. One can easily read the intersection of two lines however is there any solution to find the intercept of two lines when they aren't functions but are rather data points? Remembraning.sm (39kb) downloaded 23 time(s).
no no ...I think I was unable to make you understand. The summation gives one value ...instead I wanted to have a cumulative elements in a vector. The latter thus can be plotted. please revisit the screenshot
1 user thanked PompelmoTell for this useful post.
Sum the vectors and vectorize ...
Originally Posted by: ioncube cumulatively adds vector elements ... as you wish
Jean Giraud, why do you add Line in the following code, I mean why not just type them separately or am I missing something?
Jean, Why did you use Sum(1) with a J loop? Ioncube, Just use Sum(4) Edited by user 23 April 2018 23:16:04(UTC)
| Reason: Not specified
Joined: 15/04/2012(UTC) Posts: 1,988 Was thanked: 1125 time(s) in 722 post(s)
Originally Posted by: ioncube Jean Giraud, why do you add Line in the following code, I mean why not just type them separately or am I missing something? Yes my friend, you are missing best using Smath feature, 1. the line | collects/instructs the project 2. the { collects for plotting Visit attached Project PR EOS.smHere is your plot and cumulative. Project PR EOS.sm (130kb) downloaded 34 time(s).
Thanks Jean. I myself am a chemical engineer & Equations of state example is very much appreciated!
mkraska, thanks for helping, but your file is created with a newer version of SMATh & throws error in my current version 0.98.6528
Originally Posted by: ioncube mkraska, thanks for helping, but your file is created with a newer version of SMATh You are right: Martin latest version throws error in my 6179. I love Martin code ... Bingo ! The code I provided should work, as it did previous Smath 5346.
Originally Posted by: Jean Giraud You are right: Martin latest version throws error in my 6179. Try that in your version.
Joined: 05/06/2014(UTC) Posts: 348 Location: Colombo Was thanked: 125 time(s) in 82 post(s)
Originally Posted by: PompelmoTell sergio I tested 3 programs to find the cumulative totals of a large array of 20820 elements. The method of Sergio was incredibly fast, while other two methods were much slower. Thanks Sergio. Forgot to attach DATA file Rainfal_Data.xlsx (487kb) downloaded 16 time(s). Cumulative Sum of a Large Matrix.sm (31kb) downloaded 22 time(s).Edited by user 09 August 2019 09:39:44(UTC)
| Reason: Forgot to attach DATA file |
1 user thanked ndtma for this useful post.
3 users thanked Razonar for this useful post.
on 09/08/2019(UTC), on 09/08/2019(UTC), on 09/08/2019(UTC)
Hello Alvaro I get following result in my laptop. Yours is a very good alternative. Thanks. Edited by user 09 August 2019 17:38:33(UTC)
Originally Posted by: ndtma cumulative totals of a large array of 20820 elements. ... the word is array1. Unwrap the array in vector 2. ΣV ... vector sum over the unwrapped array SS 6179 does not open your document.
...more and otherwise. vectSum.sm (16kb) downloaded 15 time(s).
SMath Studio Forum
Questions
