Offline m227
#1 Posted : 12 April 2018 14:45:29(UTC)
m227
Rank: Member
Was thanked: 4 time(s) in 2 post(s)
Hi, i assign 460 GWh to a E variable (Giga Watt hours).
Then I want to see it in kWh (or MWh).
Trying to write E='MWh results as on picture (units are not recalculated by prefixes).
Is it normal? Do I have to add my own calculation among prefixes to obtain proper recalculation?2018-04-12 13_32_41-SMath Studio.png
#2 Posted : 12 April 2018 15:46:54(UTC)
Was thanked: 1339 time(s) in 878 post(s)
Yes, units prefixes are built-in (a variable must be declared in units.xml to accept the proper multipliers... so f.e. you can't have automatically gigakelvin or megaseconds)
SI standard
commercial/practical user-defined
Edited by user 12 April 2018 20:15:43(UTC)  | Reason: fixed hour unit
#3 Posted : 12 April 2018 18:20:34(UTC)
Interesting but rather confusing.
What is MW h
In lot of maths MW h is implicit of MW*h
Rather not same MW/h
#4 Posted : 12 April 2018 18:58:12(UTC)
In lot of maths MW hr is implicit of MW*hr
Rather not same MW/hr
I guess it is possible to make it MW/hr
#5 Posted : 12 April 2018 20:09:00(UTC)
Two very different things [W*h]=[J] while [W/h]=[J/s^2]
However, yes, can be done even this (CTRL+K to add the backslash):
Offline m227
#6 Posted : 13 April 2018 11:18:22(UTC)
m227
Rank: Member
Thank you Davide. I just realized that my unit is not a standard unit but multiplication of two. I found it out when tried to convert my results to Joules (J). So you're right, it is enough to use kW*h instead of kWh. I buy it.
Btw. unit like kW/hr and W/s (Watts per time) are rather nonsense as W is already given in a time span (J/s).
Edited by moderator 13 April 2018 13:31:12(UTC)  | Reason: marked as solved
Offline Razonar
#7 Posted : 24 April 2018 19:40:32(UTC)
Razonar
Uruguay
Was thanked: 818 time(s) in 518 post(s)
Hi "M". Just not so fast. J/s^2 can be seen as the power acceleration, like the normal "acceleration", meter by second square. It could be practical in an electrical circuit for study the variation of p(t)=v(t)*i(t) (in lowercase, which means instant values). Usual electrical protections only study the "R by I square curve" and how the current increase in time (and remember that i=dq/dt), but one must to remember that Ohm's law isn't a "true" law: it's just a practical rule, which works only ... if it works, but isn't a natural principle, like Newton's laws.
Offline crun
#8 Posted : 04 May 2018 08:27:02(UTC)
crun
A while ago I requested Engineering Exponents/Notation.
https://en.smath.info/fo...-displaying-results.aspx
You would probably find that would meet your needs also.
Even of the exponents were coerced to 3s, it would probably help - I personally find it much easier when the exponents are in 3's, even if the prefixes aren't used
Similar Topics
Add more Unit Prefixes (Feature Requests)
by Jens7 09/01/2017 22:20:57(UTC)
