Let's rename from reworked previous document. Please comment/else on that document *.sm Copy/paste from sources aren't enough compatible with SS. The model function is excellent. In fact, the conclusion is in the reverse common understanding, i.e: thickness vs temperature. The InverseFunction is given => find thickness given temperature. A superb project, maybe checked again. Thanks Elsid, most appreciated ... Jean Inst_Thermal Insulation.sm (123kb) downloaded 77 time(s).
Originally Posted by: Jean Giraud The model function is excellent. ... here is the Genfit to this model. Genfit Thermal Insulation.sm (34kb) downloaded 48 time(s).
2 users thanked mkraska for this useful post.
on 23/03/2018(UTC), on 23/03/2018(UTC)
