SMath Studio Forum
Questions
Vectors creation with ranged indices
Does anyone know how to use vectors with subscripts (by typing: [) in SMAth as I have done in the attached Mathcad file (.pdf + .xmcd). I have tried it in SMath (see the attached SMath file) but this does not work in the same way. Does anyone knows a workaround? Best regards, Rens Servais SMath file.sm (4kb) downloaded 14 time(s). Mathcad file.xmcd (20kb) downloaded 10 time(s). Mathcad print.pdf (96kb) downloaded 16 time(s).
Rank: Advanced Member Groups: Registered, Advanced Member Joined: 13/01/2012(UTC) Posts: 2,653 Location: Italy Was thanked: 1339 time(s) in 878 post(s)
Hello Rens, You can do it in the same way, but indices here are base 1 instead of base 0 SMath file (r1).sm (5kb) downloaded 19 time(s).Edited by user 21 March 2018 16:57:08(UTC)
Thanks a lot Davide! Best Regards Rens Edited by moderator 22 March 2018 13:58:32(UTC)
| Reason: marked as solved - title modified for future reference
Reminded me of a loop I had for Mathcad. Somehow, the equal sign is not correct and not working. A little help? Range2Vec program.smz (3kb) downloaded 13 time(s).
Originally Posted by: ElSid Reminded me of a loop I had for Mathcad. Somehow, the equal sign is not correct and not working. A little help? Range2Vec program.smz (3kb) downloaded 13 time(s). What would be the expected result? Edited by user 22 March 2018 17:23:01(UTC)
Joined: 23/03/2016(UTC) Posts: 277 Was thanked: 91 time(s) in 57 post(s)
You had Count as subscript instead of index in the loop. Range2Vec program.smz (3kb) downloaded 15 time(s). |
Wrong subscript ... Fixed Range2Vec.smz (4kb) downloaded 22 time(s).
SMath Studio Forum
Questions
