Joined: 21/11/2017(UTC) Posts: 114 Location: Olt county Was thanked: 1 time(s) in 1 post(s)
Greetings to everyone. I have tried to solve a system of nonlinear equations using the "GivenFind" procedure. I've attached two screenshots below with the bugs returned by the program. In the first image, the program has returned: "x - undefined" error, as can be seen. I then defined the vector x, and the program returned the error "GivenFind - the function is not defined" as in the second image. What could be wrong?
Originally Posted by: ola_nicolas "GivenFind" procedure. It is not an Smath procedure. The native procedure "FindRoots" Which to me is a non sense as you are given something and want to find. Solve GivenFind PetShop.sm (14kb) downloaded 30 time(s). Solve TREASURY_1 [Iterate L, Lc].sm (37kb) downloaded 20 time(s).
Bonjour Jean Giraud. . I tried before, including the way you suggest it. In addition I analyzed some examples I found on the forum. The results were the same. I attach a new image to one of the examples you gave me in your answer. You may notice a similar error. Therefore, please help me solve the problem.
Hello, Just suppress evaluation of the marked region. |
hello omorr. The result is the same. I have not attached a new image. I specify that if I define the sizes x, y and z, the program returns the error "FindRoot - the function is undefined" Edited by user 18 March 2018 11:23:17(UTC)
| Reason: Not specified
BTW, I still have a frustrating experience in SMath whenever I try to numerically solve a nonlinear system of equations F(X)=0 given n valued vector function F(X) with unknown vector X with n elements when, say, n >= 10. |
Originally Posted by: omorr BTW, I still have a frustrating experience in SMath whenever I try to numerically solve a nonlinear system of equations F(X)=0 given n valued vector function F(X) with unknown vector X with n elements when, say, n Bonjour Radovan, please give us an example.
Originally Posted by: Jean Giraud Originally Posted by: omorr BTW, I still have a frustrating experience in SMath whenever I try to numerically solve a nonlinear system of equations F(X)=0 given n valued vector function F(X) with unknown vector X with n elements when, say, n Bonjour Radovan, please give us an example. Bonjour Jean, ça va? We already had this discussion some time ago - see this post, please. |
Greetings to all Here is a practical and very laborious way to solve the initial problem. The three basic non-linear equations are those on a yellow background. The MathCAD program's symbolic calculation facilities were used to solve two of the basic equations in relation to the η and λ variables. The necessary substitutions were made in the third equation and I was able to define the function N (n) in this way. The equation N (n) = 0 is solved using the "solve" function in Smath. A second function (Λ (λ)) was then elaborated which was solved in turn using the same function. Finally, one of the two equations solved in relation to the variables η and λ is actually calculated. The whole calculation process lasted about 60 minutes. I wonder how long it would take if I did not have the facilities of MathCAD's symbolic calculation ?! Probably a lot of hours. What would have happened if (as Radovan had said) the number of variables would have been greater than 3 ?! It would have been frustrating indeed. Therefore, if Smath developers read this post, I think it would be good to consider the possibility of implementing a "Given-Find" and / or "Given-Minerr" computation procedures similar to those used in MathCAD. I attached here along with the image of the Smath solution, a picture of solving the same problem in MathCAD by using the "Given-Find" procedure. It lasted only as long as it was necessary to edit the necessary relationships in that spreadsheet. Otherwise, all the best. Edited by user 19 March 2018 13:20:48(UTC)
Hello, It seems that for your problem there is a solution (do not know if it is a viable one). FindRoot() will do the job here. One might consider FindRoot() similar to Given/Find in Mathcad. FindRoot3.sm (14kb) downloaded 20 time(s).Edited by user 19 March 2018 13:58:52(UTC)
Originally Posted by: ola_nicolas Therefore, if Smath developers read this post, I think it would be good to consider the possibility of implementing a "Given-Find" and / or "Given-Minerr" computation procedures similar to those used in MathCAD. I claimed for that ... no answer. Mathcad Given/Find, Given/Minerr are/were Mathsoft proprietary from "Numerical Recipes" [improved methods]. In a loop, Given/find goes up to 399 steps. In common use, past few visible conditions it's no problem. We did a project from blank knowledge up to 22 conditions, it lasted at least a week. Generally, the problem has some sort of model guide line. If NOT, pedal in patience [pedal in butter]. Given/Minerr would be a great asset in Smath. Otherwise, we have the Conjugate Gradient, just a bit more difficult to manage but 62 optimized model functions were done. The difficulty, even in Mathcad Given/Minerr [LM] is that many models are very reactive and LM fails ... only manual fit are possible. I have not yet managed to Minerr/Solve DE in Smath ... Original from Mathsoft, extended from Russian Mathcad Collabs. Cheers.
Hello @Radovan: It works @Jean Giraud: I can not comment. For now, I've managed to solve the problem. Another time I will see. Edited by user 19 March 2018 16:56:43(UTC)
Rank: Advanced Member Groups: Registered, Advanced Member Joined: 13/01/2012(UTC) Posts: 2,652 Location: Italy Was thanked: 1339 time(s) in 878 post(s)
Originally Posted by: ola_nicolas My variant is a portable one, which I installed recently and I would not want to change it for the time being. Which version? |
Hello It is 0.98.6484 but it does not matter. It finally worked. ... As it seems (to work) I have to copy the examples I download directly from the forum into a page of my program. Edited by user 19 March 2018 17:12:23(UTC)
Originally Posted by: ola_nicolas As it seems (to work) I have to copy the examples I download directly from the forum into a page of my program It is possible, there were several changes in the worksheet structure since your version, thus something from newer worksheets might confuse your version.... good that it worked within the clipboard |
Hello Finally it worked in this version
ola_nicolas, Please repost working sheet. I am not getting your solutions FindRoot(ES).smz (3kb) downloaded 15 time(s).
Hello Here's the Smath file. The other was an image file. FindRoot.sm (9kb) downloaded 26 time(s).
Originally Posted by: ElSid ola_nicolas, Please repost working sheet. I am not getting your solutions FindRoot(ES).smz (3kb) downloaded 15 time(s). This is a matter of third and fourth parameter of FindRoot() function (numerical precision). The solution will be different if you change them. Just look at the order of magnitude of the solutions. The second and third values are quite close to zero. Therefore, one might expect this behavior. |
Originally Posted by: ola_nicolas For now, I've managed to solve the problem I don't think so ! Check I recomposed correctly. GivenFind PossibleBug.sm (236kb) downloaded 19 time(s).
