2 Pages12>
Offline Vijay
#1 Posted : 15 March 2018 06:42:55(UTC)
Vijay
Rank: Member
I am trying to to the following:
n:=[1..1200]
s(n):=(1200-n)/1200
I(n):200/(1+2/s(n))
"I get an error divisor matrix must be square"
any suggestions???
Vijay
#2 Posted : 15 March 2018 08:16:37(UTC)
Originally Posted by: Vijay Go to Quoted Post
I am trying to do the following:
For God sake: what are you trying to do ?
Offline Vijay
#3 Posted : 15 March 2018 17:15:54(UTC)
Vijay
Rank: Member
Thank you for the response, I am new to this forum, is there a way I can send a .pdf file of the work I had done in MathCad, this will help you see what I am trying to do in Smath.
Vijay
#4 Posted : 15 March 2018 18:10:39(UTC)
Vijay
Try this much easier:
1. compact as much as you can your part of Mathcad
2. PrintScreen, paste in Paint, clean
3. In your C:\ ... create a directory "Snippets"
4. Try to save your Paint as *.PNG in your "Snippets"
5. then => add file from the Smath forum
by double click on the *.PNG in the Snippets directory.
Offline mkraska
#5 Posted : 15 March 2018 19:29:30(UTC)
mkraska
Was thanked: 1127 time(s) in 723 post(s)
you divide by a vector. If you want to apply that by element, then use the vectorize operator.
Alternatively, you can use implicit loops.
In any case make sure that you don't divide by zero.
To upload images or files, use the paperclip button ("Insert an existing...." )
matrix2.sm (20kb) downloaded 37 time(s).
#6 Posted : 15 March 2018 20:29:42(UTC)
Maths Matrix Vijay.sm (12kb) downloaded 18 time(s).
Offline Vijay
#7 Posted : 15 March 2018 21:43:29(UTC)
Vijay
Rank: Member
Vijay
#8 Posted : 16 March 2018 00:34:53(UTC)
Too many parameters are missing to reproduce
r1, r2, E, x [u in Smath ... back to x in plot]
Offline Vijay
#9 Posted : 16 March 2018 05:21:52(UTC)
Vijay
Rank: Member
Thank you for your efforts, that's what I am looking for. I am resending the data with all the information. I have a few questions on your previous post, there is an arrow above 2/s and I(u)^2.What is that function. Also, you have used the value of u = 13.5? Also, when you plot the graph, did you just type T(13.5) to get the graph?
#10 Posted : 16 March 2018 06:18:34(UTC)
I am re-sending the data with all the information.
1. The arrow is the vectorising operator [same as Mathcad].
2. 'u' is the wild parameter of same nature as r1,r2
3. The system runs over 'n' taken into account wrt the vectorised arguments.
4. Shift@ to get the plot region, type T(13.5) then [ to get the index operator
then type x. The Smath plot argument is 'x'. So, by indexing, it will plot over
the running 'x'. If you want to plot ln(x), just type ln(x) in the plot place holder.
I will try to code your latest information, but busy next three days.
#11 Posted : 16 March 2018 06:55:26(UTC)
Now, you have another story [a different project].
Vijay(1).sm (27kb) downloaded 32 time(s).
#12 Posted : 16 March 2018 13:46:41(UTC)
starting from the basics, hope it might help you Good
example.sm (18kb) downloaded 115 time(s).
Edited by user 16 March 2018 13:53:26(UTC)  | Reason: Not specified
on 16/03/2018(UTC)
Offline Vijay
#13 Posted : 16 March 2018 15:45:00(UTC)
Vijay
Rank: Member
Thank you so much, this really helps. May I suggest you post this as an example so everyone can benefit.
Vijay Khatri
Offline Vijay
#14 Posted : 16 March 2018 15:46:34(UTC)
Vijay
Rank: Member
Thank you, you have given me ideas that I can try to implement.
Edited by moderator 08 April 2018 13:57:51(UTC)  | Reason: marked as SOLVED
#15 Posted : 16 March 2018 16:18:52(UTC)
Back to original.
Vijay(1).sm (8kb) downloaded 20 time(s).
#16 Posted : 16 March 2018 18:49:43(UTC)
You can mine Smath by visiting "Samples".
Without the circuit, it looks dead.
Offline Vijay
#17 Posted : 16 March 2018 19:46:53(UTC)
Vijay
Rank: Member
Attached is another similar file for which I have included the circuit diagram. I am assuming this will be posted in samples in this foroum.Induction Motor.pngInduction motor 2.png
Offline CBG
#18 Posted : 17 March 2018 01:47:03(UTC)
CBG
Something like this?
Vijay_CBG_Jean.sm (14kb) downloaded 25 time(s).
Carlos
#19 Posted : 17 March 2018 02:55:29(UTC)
Visit => Samples => Motor Analysis [20180316, 19:52]
Drawing was sharpened to the possible limit,
if you have a better one, please offer.
Offline Vijay
#20 Posted : 17 March 2018 03:05:16(UTC)
Vijay
Rank: Member
Carlos
Thank you Carlos, just one question, how did you create the vertical line with multiple entries.
Guest (2)
2 Pages12>
