Offline CBG
#1 Posted : 23 January 2018 23:56:29(UTC)
CBG
I could not find in the forum how to change Smath Studio from 64 bits to 32 bits.
What is the procedure to do it, since several plugins do not run in 64 bits?
Carlos
Offline alyles
#2 Posted : 24 January 2018 00:12:20(UTC)
alyles
Check out this post. https://en.smath.info/fo...thcad-EFI.aspx#post12501
I believe you need the corflags download provided by uni.
Edit: The specific post you need is about half way down the page. One post shows the command and the other provides the files.
Originally Posted by: uni Go to Quoted Post
SMathStudio_Desktop_0.97.5189_32bit
How to get this 32-bit version (MSVS2010):
Code:
CorFlags /32bit+ SMathStudio_Desktop.exe
Good
CorFlags attached.
Edited by user 24 January 2018 00:16:02(UTC)  | Reason: Not specified
#3 Posted : 24 January 2018 22:36:14(UTC)
Carlos
Thanks Carlos for your pertinent remark 32/64 bits.
What is the use of 64 bits, particularly wrt plugins ?
bits and bits are confusing ... explain:
My Windows version of Kalkulator 1995 2.27 is 32 bits.
its gives me ln(2) => 0.639147180559945309
same as Mathcad 18 floating.
Remember that all common math functions are 21 floating points.
Windows retains only 15 displayed to take care of error propagation.
On the other hand: what is the point of 64 bits if public math functions
are on base 21 floating points from 32 bits ?
Offline CBG
#4 Posted : 24 January 2018 23:34:44(UTC)
CBG
Jean, I do not understand either, since the standard version of Smath studio is 64 bits,
and is constantly being updated to improve it, but the plugins do not follow that
same rhythm of updating, resulting in many functions not working properly.
Carlos
Offline CBG
#5 Posted : 25 January 2018 00:13:35(UTC)
CBG
Thank you very much Alyles for your answer, now I have Smath Studio in 32 bits,
but even so I can not follow the example of Jean called "Page1 Randomize Matrix.sm",
it gives me the error "Random () Function is not defined
Carlos
Offline alyles
#6 Posted : 25 January 2018 00:40:09(UTC)
alyles
Carlos,
Do you have the statistical tools plugin installed?
That is required for the Random(2) function.
Offline CBG
#7 Posted : 25 January 2018 01:50:50(UTC)
CBG
Quote:
Carlos,
Yes I have it
Carlos
#8 Posted : 25 January 2018 11:45:48(UTC)
Carlos, could you try if the problem persits even in a portable distribution? (here the one shared by Martin Kraska, here instructions to make one by yourself)
Offline CBG
#9 Posted : 25 January 2018 19:18:40(UTC)
CBG
Davide, previously had already checked with the portable
distribution of Martin Kraska and the file runs without
any problem, recognizing the statistical functions.
As the portable distribution is 32 bits, I thought that
the problem was that Smath Studio to 64 bits, did not
recognize the statistical tools plugin
#10 Posted : 25 January 2018 21:01:58(UTC)
I thought that
Too many Beta versions.
Update bugs from Stable versions is more appropriate [IMHO].
Maybe good idea to evaporate your latest Beta and re-install 6179.
Since 6179 was published stable, no bugs found.
This morning, just discovered bug in Formatted Label [6484].
Beta testing needs to run a large collection.
My *.sm collection is now very large and would take > one week,
and she is only maths [NO Combobox, Checkbox, Modeller, Snapshot ...]
That was just out of mind.
#11 Posted : 25 January 2018 23:15:43(UTC)
the problem as that Smath Studio to 64 bits, did not
From your screenshot seems that the plgin is recognized (green in loaded plugins) but the functions are not loaded for some reasons. I have recompiled the plugin for the latest SS beta, please try if this works for you (plugin recompiled as beta too).
Edited by user 25 January 2018 23:17:57(UTC)  | Reason: Not specified
Offline CBG
#12 Posted : 25 January 2018 23:56:33(UTC)
CBG
Hello Davide
The plugin has a very strange behavior.
I deleted the current plugin and loaded the updated, ran the file and executed perfectly.
I closed smath studio and reopened it, ran the file again, and the statistical functions were not recognized again.
Carlos
#13 Posted : 26 January 2018 05:17:22(UTC)
Hello Davide
Carlos
Delete does not do what you expect. You must evaporate
"evaporate" is my word to make understand what it has to do.
What you have to do may depend upon Win Registry.
Smath has only two Registry entries that can be rocognized
maybe there are more. My understanding is that Delete does not
act in the Win Registry, that's why on re-opening, it takes
back the previous Registry.
When installing Mathcad 11, we had to "evaporate" any/all
Mathcad/Mathsoft in all Registry Keys.
Evaporate did doctor 100's +++ new MCD 11 users.
On the other hand the matrix size is too huge for 6179.
Alternately, it turns the work sheet blank, open new sheet, go back.
Instead of turning blank, it may just reply Random(,,) Not defined.
On the other hand, the new Smath 64 bits may not be be compatible to
the maybe 32 bits Statistical plugin. If so, real disaster ...
it would turn red ~ 3 dozens documents from my collection [suicide case].
Added: a refreshed version.
Random_5 Matrix [RGB].sm (103kb) downloaded 10 time(s).
