Offline - Norm -
#1 Posted : 16 January 2018 22:57:54(UTC)
- Norm -
Was thanked: 9 time(s) in 7 post(s)
Transferring a MC sheet. How can I solve for the unknowns? BJT Circuit Analysis.sm (55kb) downloaded 30 time(s).
Offline alyles
#2 Posted : 16 January 2018 23:48:31(UTC)
alyles
For using Linsolve(1) function, you need to put the system of equations into a matrix. The result computes the unknowns in alphabetical order, I believe. You can retrieve this information using Unknowns function.
BJT Circuit Analysis.sm (64kb) downloaded 44 time(s).
Offline - Norm -
#3 Posted : 17 January 2018 00:45:55(UTC)
- Norm -
Many thanks!
#4 Posted : 17 January 2018 04:15:48(UTC)
Unknowns("variable"Wink - ... from f(x) menu
Returns a vector of unassigned variables contained in "1:variable".
If unknowns are not found, returns 0.
Solutions are returned in lexicographic order ... inspect Unknowns(A)
#5 Posted : 17 January 2018 05:41:57(UTC)
... thanks for this LinSolve application.
Maths LinSolve.sm (70kb) downloaded 62 time(s).
#6 Posted : 17 January 2018 10:03:40(UTC)
Here is another MCD sheet, converted Smath [circuit application].
Iterative solvers are common in Engineering.
Solve TREASURY_1 [Iterate L, Lc].sm (59kb) downloaded 43 time(s).
Offline - Norm -
#7 Posted : 17 January 2018 16:33:57(UTC)
- Norm -
Thanks Jean, for the Solve Treasury worksheet. I updated my sheet splitting the ampere and voltage values apart.
Best regards,
Norm BJT Circuit Analysis.sm (50kb) downloaded 21 time(s).
Offline alyles
#8 Posted : 17 January 2018 17:07:30(UTC)
alyles
I've modified the LinSolve(1) function and created a LinSolve2(2) function that allows user to specify result order vector. I've named it LinSolve2 to avoid confusion with the LinSolve(2) Maxima Plugin function.
Not sure if this is useful for anyone.
BJT Circuit Analysis (1).sm (87kb) downloaded 41 time(s).
#9 Posted : 18 January 2018 07:23:34(UTC)
Lovely separation of result.
A useful companion attached, more examples in future.
Solve LinSolve COMPANION.sm (32kb) downloaded 46 time(s).
Offline alyles
#10 Posted : 18 January 2018 15:35:41(UTC)
alyles
Jean, I believe the original LinSolve function is a snippet created by Martin (mkraska). You can find it within the Snippet Manager in SMath.
#11 Posted : 19 January 2018 18:07:33(UTC)
I think so ... those gyzmas # are Martin style.
Easy to removed all # ... like this
1. start by the LHS in the program definition
2. put the cursor on the right of the #
3. press F8 to see all selected, in the program core as well
4. once selected, press Backspace ... gone
5. next proceed in the core of the program
6. result => nice and clean
Cheers
