I read the other post on subscripts. I am looking direction on how to use a single subscript for use in an array. See mathcad "Seeded Iteration" example here: http://www.imakenews.com/ptcexpress/e_article000950717.cfm?x=bbPFVppPer another posting, I also realize that units are not built in ... yet As a request, now that SMath can read mathcad files, can we save to mathcad files? Also, what are the short cut keys that you have programmed in? I love the fact that this is so much like Mathcad!
Hi. Single subscript, Units, Mathcad files saving would be added in future versions. Here is the complete list of shortcuts: Ctrl+Z - Undo changes Ctrl+Y - Redo changes Ctrl+X - Cut Ctrl+C - Copy Ctrl+V - Paste Ctrl+M - Insert Matrix Ctrl+E - Insert Function Ctrl+T - Insert blank Image Ctrl+. - Symbolic calculation of the equation Ctrl+Shift+P - Insert PI constant (3.1415...) \ - Insert square root Ctrl+\ - Insert n-th root [ - Insert el() function - subscript
