SMath Studio Forum
Questions
How to solve Berlin Airlift Linear Optimization Problem
Joined: 04/12/2017(UTC) Posts: 61 Was thanked: 2 time(s) in 2 post(s)
How will you go about solving following problem in Smath Problem statement is as follows: Quote:On June 24, 1948, the former Soviet Union blocked all land and water routes through East Germany to Berlin. A gigantic airlift was organized using American and British planes to supply food, clothing and other supplies to more than 2 million people in West Berlin. The cargo capacity was 30,000 cubic feet for an American plane and 20,000 cubic feet for a British plane. To break the Soviet blockade, the Western Allies had to maximize cargo capacity, but were subject to the following restrictions: No more than 44 planes could be used. The larger American planes required 16 personnel per flight; double that of the requirement for the British planes. The total number of personnel available could not exceed 512. The cost of an American flight was $9000 and the cost of a British flight was $5000. The total weekly costs could note exceed $300,000. Find the number of American and British planes that were used to maximize cargo capacity. Based on this the author & using an online LP solver I have: http://prntscr.com/hpk4j5
You can use the "simplex" package in Maxima (linear optimization) See page Examples> Maxima usage> Linear optimization in the interactive handbook. Example maxima linear optimization.sm (42kb) downloaded 24 time(s). |
Originally Posted by: ioncube How will you go about solving following problem in Smath Maybe plot the problem 1rst ? Next solve solely with Smath, whereas Maxima is not component of stable 6179.
Thanks for the answers Jean would you be kind enough to attach the .sm file too. For field engineers like us your math skills seems rather cryptic & is digested properly after 2/3 days of experimenting
Originally Posted by: ioncube Thanks for the answers Jean would you be kind enough to attach the .sm file too. Here is + some extra stuff. Maybe there is way to draw an inscribed 3D ? Jean Solve GivenFind Critical Region Copy.sm (40kb) downloaded 28 time(s).
Using Smath Studio with Maxima and the example of Martin Kraska. Metodo_Simplex.sm (53kb) downloaded 24 time(s).Best Regards Carlos
Here is a small and simple Simplex algorithm without the use of the Maxima function. Small_Simplex_Algorithm.sm (17kb) downloaded 23 time(s).Best regards Carlos CAUTION: The algorithm is NOT TESTED, but it works well for this example. It is necessary to refine it so that it work in all cases. Edited by user 21 December 2017 22:13:26(UTC)
| Reason: Not specified
1 user thanked CBG for this useful post.
Thanks Carlos for the "Simplex algo"
Originally Posted by: CBG I'm sorry, I found a bug in the Simplex algorithm. That huge number in the program, can be replaced by ∞ [Smath machine number] RemToDo => check vs Mathcad First A[i ... badly indexed. Small_Simplex_Algorithm_Improved_2.sm (141kb) downloaded 28 time(s).
Thanks Jean, Now we just have to continue testing the Simplex algorithm, to identify possible faults.
regards
Carlos
Originally Posted by: CBG Thanks Jean, Now we just have to continue testing the Simplex algorithm, to identify possible faults. I have tested only this one => 1/1 Mathcad 11 Gorgeous, hope for more good ! Jean Undocumented Copy.sm (26kb) downloaded 33 time(s).
SMath Studio Forum
Questions
