SMath Studio Forum
Questions
Error Message: Root Element is missing.
Was thanked: 8 time(s) in 7 post(s)
I try to open a file that I created with 0.89 in 0.9 and I am getting the error message: Root Element is missing. Any idea? Thank you, Basile Edited by moderator 17 February 2012 10:20:20(UTC)
| Reason: Not specified
Could you put put a link to the particular file, please?.
Regards, Radovan |
Radovan,
I just realized that the file is empty. This should have not been the case, I saved a working evaluation of a formula.
Basile
Hello, Quite strange An empty file (at least it looks that way) with the message "Root Element is missing" when tried to be open. Have no the slightest idea. Maybe to to try reproduce what you have done? I also tried to make an empty text file and save it with the *.sm extension. The same message appeared. Regards, Radovan Edited by user 26 January 2012 17:22:45(UTC)
Radovan,
I think I found something.
Do qa simple calculation like:
Q:=10 V:=30
E:=Q*V E=
Then save the file as "Test" Then save the file again as "1.10" (Chapter 1 problem 10) The second file is empty with the error message when you try to open it.
Thank you, Basile
Hello Basile,
It seems that period-point like in 1.10 is sometimes not allowed in the SMath file name.
I think the more problematic thing here is that SMath will not tell you that the file has not being saved (at least that happened to me). For instance if you open SMath the worksheet will have the name "Page1" . If you try to save your file with the name say "10.1" it will be saved without *.sm extension and will be empty. The worksheet name - file name will still remain "Page1". But if you save it as "10.1.sm", actually just add the extension - it will be saved and will not be empty. I hope you can reproduce this.
Regards, Radovan |
Radovan,
Yes you are right. I guess, for now, the rule is: "when the file name includes a period, we have to add the extension". I hope it will be fixed soon.
Thank you, Basile
Reproduced and fixed. Thanks for the report!
Regards.
Joined: 08/03/2012(UTC) Posts: 1 Location: Lima, Perú
Guys, I'm trough the same root missing error, but this time my file isn't named using a dot character. My laptop have been shooting down ill-timmed and once I was using the file, happened. Does the file have any solution? The file is stored at https://drive.google.com...cE9zWFU/view?usp=sharing . Tnx
Rank: Advanced Member Groups: Registered, Advanced Member Joined: 13/01/2012(UTC) Posts: 2,648 Location: Italy Was thanked: 1329 time(s) in 875 post(s)
Originally Posted by: f.arenas Guys, I'm trough the same root missing error, but this time my file isn't named using a dot character. My laptop have been shooting down ill-timmed and once I was using the file, happened. Does the file have any solution? The file is stored at https://drive.google.com...cE9zWFU/view?usp=sharing . Tnx Unfortunately this file is unrecoverable. The problem has been addressed recently and should never happen anymore with the most recent versions of the program (fix introduced in SS 0.98.6398 beta). Edited by user 19 October 2017 13:31:14(UTC)
Hello, I have a problem opening my Smath file. It says "Root element is missing". Earlier today I made a pdf of my file and saved it and thought everything was ok. I even checked the PDF version of my file and everything seemed to be ok. But later in the evening when I wanted to check my work again, the PDF file was completely gone from my computer and when I tried to open my Smath file it gave me the error "Root element is missing". After clicking OK it opens a completely empty file. It was a pretty big file, 10 pages long in PDF version. Is there any way I can recover my work? Thanks in advance. EDIT: i forgot to put the link where the file is: https://drive.google.com...miC2qaqjuLLROMs03DE/viewmod edit: file attached for future reference UL3_Lauk.sm (162kb) downloaded 8 time(s).Edited by moderator 13 December 2017 19:20:31(UTC)
Originally Posted by: Lauri Is there any way I can recover my work? Absolutely NOTClick on your file name ... 0kB ... gone when Smath crashed. It may simply have crashed at the closing of the file, while everything seemed to be working fine in session. Now, you will never work so long pages and not alternate a copy. Wise also to save the *.PDF under new name.
Originally Posted by: Lauri Hello,
I have a problem opening my Smath file. It says "Root element is missing". Earlier today I made a pdf of my file and saved it and thought everything was ok. As said by Jean unfortunately there's nothing to recover here. What version of SMath Studio are you using? In the most recent versions (f.e. latest stable) you should notice an error message while saving and the original file is kept as it was at the previous successful save (at least this how it should works). Originally Posted by: Lauri the PDF file was completely gone from my computer That's really strange (pdf isn't under the control of SMath Studio), probably is still in the default pdf output path or there might be something in a temporary path. Edited by user 12 December 2017 21:56:26(UTC)
Originally Posted by: Davide Carpi the PDF file was completely gone from my computer Assume you would need to publish your Smath document as *.PDF. Use the $50 PDF from "Nuance", you can save it under new name as an independent entity, with plenty of features. ... However ... it happens from unexplained, that while in Smath session, everything works fine but a silent bug exist and does not save and maybe will not save *.PDF as well. All CAS have bugs [Mathematica, Maple, Mathcad ...]
SMath Studio Forum
Questions
