Is possible to make calculation in table, like excel?
Originally Posted by: Paulius Is possible to make calculation in table, like excel? Your question is too vague, a bit of work sheet would help. In short: there is no known limit about what Smath can do within a matrix [its own matrix] wrt the project you are Engineering. Then, you may send to Excel via Alex plugin. Alex, please correct me if wrong ! Cheers.
Joined: 02/06/2017(UTC) Posts: 18 Location: Stoke on Trent
Hi Paulius, I had a similar problem. I wanted to create a table of values for a project at work that could be easily read by non SMath people (i.e. I wanted a nice looking table but also array names with text to identify the value rather than numbers) Some of the values were fixed (sizes , powers or text ) but I needed to perform calculations on some of the values and incorporate it in a table. I came up with the following method using TableRegions , although it looks a little complicated it works great and generates a great looking table and I can use arrays with meaning full text identifiers. The attached file is annotated so should be fairly self explainatory and there are some examples of how to use the values at the bottom. If you have a problems with it let me know. TableRegion example by PJF.sm (31kb) downloaded 153 time(s).Regards Peter |
Peter J Francis
Twitter: @PeterJFrancis
Thermal Engineer , Maker , Pilot
2 users thanked Jean Giraud for this useful post.
on 15/11/2017(UTC), on 15/11/2017(UTC)
Originally Posted by: Jean Giraud Originally Posted by: Paulius Is possible to make calculation in table, like excel? Your question is too vague, a bit of work sheet would help. In short: there is no known limit about what Smath can do within a matrix [its own matrix] wrt the project you are Engineering. Then, you may send to Excel via Alex plugin. Alex, please correct me if wrong ! Cheers. Agree with Jean - you can do all sorts of operations in SMath with matricies and then present them as a table region OR you could use excel to do an present all the table stuff for you.
