Offline Dave.ca
#1 Posted : 04 October 2017 05:38:03(UTC)
Dave.ca
I've tried many ways from examples I have found on the internet, but I just can't get the graph to plot. What am I doing wrong?
Any help would be greatly appreciated.
[b]Foot note:
The problems are solved. The main problem was units; units must be correct through out. When using constants be sure the value also has units attached (1.5 m, not 1.5, for example). The second was that for the extended graph plugin there seems to be a limit on the levels of conditional functions you can call. I ended writing the function as a one line which worked:
Quote:
m(x)={((x≥0m)&(x<L1))*M1(x)+((x≥L1)&(x<L1+L2))*M2(x)+((x≥L1+L2)&(x≤Ltot))*M3(x)}/1000
Edited by user 08 October 2017 20:32:27(UTC)  | Reason: Not specified
Offline csb531
#2 Posted : 04 October 2017 12:08:56(UTC)
csb531
Rank: Member
Netherlands
Hello Dave,
maybe a simple scaling problem? Your results are of magnitude 8 N, your plot is in [kN].
Try scaling the plot area with [Ctrl]+scroll wheel or [Shift]+ scroll wheel.
Hope this helps...
Regards, csb.
#3 Posted : 04 October 2017 13:51:33(UTC)
Dave, please attach the work sheet.
Offline Dave.ca
#4 Posted : 04 October 2017 17:19:15(UTC)
Dave.ca
Here Jean, thanks for looking
Dave MAST.sm (1,470kb) downloaded 22 time(s).
#5 Posted : 04 October 2017 18:07:09(UTC)
Input units are needed... in the standard 2D plot, just use p(x*'m) / V(x*'m)
#6 Posted : 04 October 2017 18:18:53(UTC)
1. The X_Y plot does not take conditional
2. Quick plot does not take units [there is way to trick]
3. units removed from the two conditional ... plots !!!
Cheers... Jean
MAST.sm (1,473kb) downloaded 30 time(s).
Offline Dave.ca
#7 Posted : 04 October 2017 19:31:53(UTC)
Dave.ca
Yahoo! Thanks Jean! I understand the problem!
Dave
