  Rank: Administration Groups: Developers, Registered, Knovel Developers, Administrators, Advanced Member Joined: 11/07/2008(UTC) Posts: 1,614   Was thanked: 1977 time(s) in 665 post(s)
SMath Studio 0.98.6047 available - Updating of Scrollbar Bookmarks fixed on region Delete and Undo/Redo operations;
- Performance significantly increased when opening worksheets (invisible Regions do not call for invalidation of the worksheet anymore);
- SS-2325: Scrollbars related multithreading issue appeared sometimes when working with scrollbars fixed;
- Initial implementation of the built-in debugging tools completed (set breakpoint [Ctrl+F8 or context menu] and recalculate a worksheet);
- Pause button is available on main toolbar now - it allows to pause calculation and see an exact place where calculation is in progress;
- Plug-in name included into the Tooltip for functions/variables/operators;
- Arctan2() function implemented (see known issues below).
Updated 22 July: - All breakpoints shown on the vertical scrollbar now, even if they are all in the same region;
- Issue regarding plug-ins back-compatibility related to debugging fixed;
- Context Menu with Copy button implemented for the list in Watch panel;
- Fixed issue when unwanted selection appeared sometimes on debugging;
- Errors appeared during calculation immediately displayed on vertical Scrollbar now.
Updated 24 July: - Tooltips implemented for items in Watch panel;
- Calculation logic improved for better support of existing worksheets created by previous SMath Studio versions;
- Critical issue fixed appears on opening Dynamic Assistance list without any Evaluable Region before the cursor;
- Plug-ins related back-compatibility issue fixed.
Known issues - Debugging: Hotkeys for debugging not assigned yet (except Ctrl+F8 for toggling breakpoints);
- Debugging: Breakpoints set on numbers may not work;
- Calculation: Function atan(2) has couple of issues;
- Backcompatibility: Some of the worksheets will not be correctly recalculated still (issue related to undefined variables in definitions).
- Interface translation: Some strings is not translated yet (they even not registered in translation service).
Download Edited by user 25 July 2016 02:17:57(UTC)
| Reason: Not specified
 9 users thanked Andrey Ivashov for this useful post.
on 22/07/2016(UTC), on 22/07/2016(UTC), on 22/07/2016(UTC), on 22/07/2016(UTC), on 22/07/2016(UTC), on 22/07/2016(UTC), on 22/07/2016(UTC), on 22/07/2016(UTC), on 24/07/2016(UTC)
Updated with new links to the corrected build (plug-ins back-compatibility fixed).
 4 users thanked Andrey Ivashov for this useful post.
on 22/07/2016(UTC), on 23/07/2016(UTC), on 23/07/2016(UTC), on 23/07/2016(UTC)
on 25/07/2016(UTC), on 25/07/2016(UTC), on 25/07/2016(UTC)
Joined: 19/11/2016(UTC) Posts: 1  Location: Kurdistan
Sir, This is not related to your topic. But simply I have a simple question.
If I would like to upload a worksheet, how this can be done?.
Kind regards.
Ahmad Allawi
Retired Consultant Electrical Engineer-Lecturer
PTC Community Member-4009681/Mathcad Prime2.0 and 15-M10
+9647507473739 and +9648963122
Iraq
Joined: 04/07/2015(UTC) Posts: 6,723  Was thanked: 961 time(s) in 789 post(s)
Originally Posted by: Ahmad Allawi  If I would like to upload a worksheet, how this can be done?. Example: in the conference "Questions" click on "New topic" that will bring the line menu up there, click on "trombone symbol" ... upload a new file, double click in the work sheet in your system. Finally, click on "Upload", then "Post" below. You can proceed same way in any of the conference [Samples, Bugs ...] Cheers, Jean
