SMath Studio Forum
Questions
Polynomial Division Output Issue?
Greetings! First post; first use of SMath! Glad to be here... Found the SMath project while looking about for a modern replacement of my trusty old MathCad. It's quite aged; and I need something I can also use on Linux without resorting to Wine. Need the WYSIWYG man-readable interface; as my life is complicated enough without getting into the pointy-head commandline style of equation entry. 4*s on that critical point for SMath v.0.98 However, what brings me to the forum is best encapsulated with the following screenshot from my Windows machine while running both MCAD and SMath on the same polynomial division problem: As you can see, MathCad 4 gets it together when calling "simplify"; and SMath, though 24 years newer, seems to miss the point wholeheartedly during the same operation. As a quick threshold criteria, I'm looking for a robust, concise output to ply when challenged with the basic task of polynomial long division. So here's my question: Are there any plugins/configurations which can make this happen with SMath as expected? Thanks again; and have a great day!
Originally Posted by: Q137 Are there any plugins/configurations which can make this happen with SMath as expected Sure: the Smath symbolic engine is 'maple' ... not completely coded but works great for most current needs, example Laplace stuff. Same as Mathcad: after the maple expression Ctrl+. for the symbolic expansion. Jean Poly Test.sm (161kb) downloaded 31 time(s).
Rank: Advanced Member Groups: Registered, Advanced Member Joined: 10/11/2010(UTC) Posts: 1,495 Was thanked: 1275 time(s) in 746 post(s)
Originally Posted by: Jean Giraud Sure: the Smath symbolic engine is 'maple' ... not completely coded maple() - just a function from the plugin. SMath Studio has its own symbolic engine. |
Originally Posted by: Q137 and I need something I can also use on Linux without resorting to Wine. maple plugin not working for the current build in linux, but it can. Wine must be installed because plugin use it. |
Thanks for the feedback; and for the tips -- Have a great day, folks
SMath Studio Forum
Questions
