SMath Studio Forum
Samples
Corrupted Files, Unwanted Changes, Backup, Versioning - Use AutoVer
Figured I should share this with the community. How often does it happen to you that the file you are working on needs to be restored to an earlier version? For any reason. If often, one particular solution that works is using AutoVer in conjuction with, say 1TB hard drive. This little software will create versions of file for you when you modified, up to a certain maximum per hour. http://beanland.net.au/AutoVer/Here is a set of starting settings that work for me:
2 users thanked Alex M. for this useful post.
on 21/01/2017(UTC), on 21/01/2017(UTC)
Joined: 05/06/2014(UTC) Posts: 348 Location: Colombo Was thanked: 127 time(s) in 82 post(s)
Thank you Alex. I will try it.
Best Regards ndtma |
Save backward version will be valid once Smath will no longer be "beta" and best debugged. The 6179 statistical package is dead, the Gram-Schmidt polynomial 'x' does not plot, toke me at least 24 solid hours to doctor Legendre [just posted minutes ago] +++ all the plugins involved.
Saving Mathcad 11 <= 2001i <= 2000 <= 8 <= 7 was no problem because Mathcad 11 was essentially 7. Given find, Radau, grid color, less Given/Find 250 [7], 399[11], 2011i indexed as variabe ...
My compendium 11 especially done for PTC, done from my all times virgin machine did crash repeatedly PTC Mathcad 14 at PTC home. Vice versa, PTC 14 saved 11 did open two ways: either crash my 11 or plot rain like a grave yard of flies legs.
Just a comment
SMath Studio Forum
Samples
