SMath Studio Forum
Bugs & Problems
Application run Exception for version 0.89.8
Hi I download the latest version 0.89.8 and after install, I run the sMath, got the following popup: (I don't know why I can not post a picture here, so I descript it below by text popup window title: "Microsft .NET Framework" Content: Unhandled exception has occurred in your application. If you click Continue, the application will ignore this error and attempt to continue. If you clcik Quit,the application will close immediately. Method not found: 'Viod SMath.Manager.GlobalParams.set_ArgumentsSeparator(Char)'. By the way, I installed 0.89 stable version and runs well. Thanks to this great tool!
You should follow the instructions from the download page: smath wrote:Previous version of SMath Studio should be removed before installation. Regards.
SMath Studio Forum
Bugs & Problems
