Offline Alex M.
#1 Posted : 03 January 2017 03:33:38(UTC)
Alex M.
I would like to share an example of function that extracts rows from a data table based on set value in selected columns:
VLOOKUPdataparse.sm (18kb) downloaded 48 time(s).
thanks 1 user thanked Alex M. for this useful post.
on 03/01/2017(UTC)
Offline Alex M.
#2 Posted : 03 January 2017 03:39:38(UTC)
Alex M.
I do need help with an interesting behaviour of a matrix definition:
If an element of a defined matrix contains a user defined function with an undefined parameter it may inthrow an error similar to here (same SMath file as above):
I would expect the function with undefined parameter to return itself instead of giving an error code.
#3 Posted : 03 January 2017 13:06:30(UTC)
Very nice Good
I think the issue comes out because there isn't a way to stop the preprocessing in user-defined functions when you pass an unknown (and an unknown is not a valid input).
A workaround that might be useful even to avoid the use of other functions is to use a string as input in the second row, and a check in your lookup like this:
Edited by user 03 January 2017 13:08:28(UTC)  | Reason: Not specified
on 03/01/2017(UTC),  on 03/01/2017(UTC)
Offline Alex M.
#4 Posted : 03 January 2017 15:06:46(UTC)
Alex M.
Davide,
Is the a reason why function like findstr() does not return itself when not all variables are defined? Similar to this:
http://en.smath.info/for...-function.aspx#post36158
Also I am not sure if this is similar, but after I modified my excel_IO() function to return FALSE if undefined variables were present it would preprocess correctly with undefined variables when passed as an argument to a user defined function (you and I had an email discussion about this).
P.S.: the reason why a more general solution is desired is because a one might want to implement a more complex boolean check, than <>=!
Edited by user 03 January 2017 16:22:57(UTC)  | Reason: Not specified
#5 Posted : 03 January 2017 18:37:22(UTC)
It is by design. However even returning itself, you will have always var=findstr(...) -> false -> ... (it doesn't prevents the strcont() function to be evaluated)
Yes, but with functions created on the canvas this isn't possible Unsure
You can try with this:
strcont() is defined locally to avoid the preprocessing on the canvas
try() function is added because when you use el(...) inside the lookup function, all the elements of the condition matrix are evaluated -> you have to allow any type of input as first argument or let it fails silently (because strrep requires strings); note that if the selected element of the condition matrix is the one that contains strcon() with a wrong type as first argument, the error string will trigger an error on bool#:eval(bool#*operand#), because operand# will be a string.
Edited by user 03 January 2017 18:45:32(UTC)  | Reason: Not specified
#6 Posted : 03 January 2017 21:06:28(UTC)
Alex,
The attached proposal is for fixed "credit".
It might be ranged via bolean.
Alex VLOOKUPdataparse.sm (34kb) downloaded 42 time(s).
on 03/01/2017(UTC)
Offline Alex M.
#7 Posted : 03 January 2017 21:37:30(UTC)
Alex M.
Alex,
Thanks, Jean. I havent used "truth tables" yet; they seem to work quite well.
Offline Alex M.
#8 Posted : 07 January 2017 02:53:23(UTC)
Alex M.
Is there a quicker way to assemble a SMath matrix from rows than stack()?
In vb.net I can assemble 13x10000 SMath matrix in 3.3 seconds (excel_OUT), while stacking of 488 rows (13 elements each) into matrix within SMath takes 21 seconds
Thanks!
Edited by user 07 January 2017 02:55:46(UTC)  | Reason: Not specified
#9 Posted : 09 January 2017 13:49:47(UTC)
Hello Alex, can you attach an example where stack it is so slow?
#10 Posted : 09 January 2017 16:31:18(UTC)
Alex,
It depends what you assemble, and how.
Three examples attached.
Alex Assemble Matrix.sm (32kb) downloaded 28 time(s).
Offline Alex M.
#11 Posted : 09 January 2017 19:52:25(UTC)
Alex M.
Here it is - I use EXCEL to input 10000 x 13 matrix into SMATH - 1.2 seconds. Vlookup() loop to stack 400 rows - 15 seconds. Vlookup() loop which does not stack anything is 3 seconds.
VLOOKUPslow.sm (28kb) downloaded 36 time(s).
DATA.xlsx (1,652kb) downloaded 48 time(s).
Edited by user 09 January 2017 20:02:23(UTC)  | Reason: Not specified
#12 Posted : 10 January 2017 03:06:51(UTC)
Try this; basically removes all stack() calls to build the matrix after you check all the conditions. On my notebook is 50% faster than your.
VLOOKUPfast.sm (32kb) downloaded 99 time(s).
Edited by user 10 January 2017 03:08:24(UTC)  | Reason: Not specified
on 10/01/2017(UTC)
Offline Alex M.
#13 Posted : 10 January 2017 03:13:40(UTC)
Alex M.
Much better, thanks.
Could you explain how does the following exactly work:
resultrng#:el(data#,matches,range(1,cols(data#)))
#14 Posted : 10 January 2017 03:32:49(UTC)
You're welcome Good
It is this feature; in the 2nd argument of el(3) there are all the rows I want from first argument's matrix, as 3rd argument all the columns. The result is a matrix of the elements that fits both the requirements, in the given order.
Edited by user 10 January 2017 03:43:37(UTC)  | Reason: Not specified
Offline dxyont
#15 Posted : 23 April 2021 06:20:54(UTC)
dxyont
thank you for sharing these function, lookup is another essential features of spreadsheet and could be better if it has to be include in standard distribution.
from vlookupfast.sm modification, may it be simplified for such a situation below. in case condition only use boolean 'equal to' as the same in any spreadsheet function.
Edited by user 23 April 2021 06:26:24(UTC)  | Reason: Not specified
#16 Posted : 23 April 2021 21:29:41(UTC)
There area dozen of lookup. If so many for so many applications.
Be more specific c/w *.sm document.
#17 Posted : 23 April 2021 21:36:59(UTC)
... visit this intelligent/advanced lookup.
Utilities Matrix Locate Array1 Array2.sm (71kb) downloaded 29 time(s).
Guest (2)
